#3331 | |
The waveguides are way too small to be effective and they terminate in shrp edges - both very bad ideas. |
#3332 | |
Lynn Those companies that you mentioned are just about the strongest NIH places that I have ever seen. They use others ideas and then act as if they thought of them - the ultimate NIH. Its your time domain ideas that I agree with most since this is where I am finding the strongest correlation with subjective sound quality. Its the nonlinear distortion things that I agree with least because I used to believe in nonlinear distortion, but then as I studied it I found that it wasn't a factor, but time domain stuff was. And, by the way, you do know that line arrays always have "tails" in their impulse responses - they have to - which means that they can never have compact impulse responses. Only point sources can have a compact impulse response. Good luck |
#3333 | |
Additionally, I think that the sphere type baffle that smooths the edges to minimize edge diffraction is very necessary for good imaging.
Hear the real thing! |
#3334 |
Are their AES papers or other peer reviewed sources to look at that show:
"And, by the way, you do know that line arrays always have "tails" in their impulse responses - they have to - which means that they can never have compact impulse responses. Only point sources can have a compact impulse response." Regards, C |
#3335 | |
#3336 |
Is there anywhere in the San Francisco bay area where a pair of your Summa speakers can be auditioned?
Thanks, C |
#3337 | ||
I surely don't know - so I trust You but the midtweeter (800 Hz and up) waveguide looks bigger than in Summa or AI-Audio it's about 60x30 cm and the midbass waveguides match the midtweeter waveguide and it looks that this was just their purpose, no bigger needed as to sharp edges - they quite standard, aren't they? also among horn classic like Klipschorn, big JBLs etc. I know (from Your posts) that it is very bad idea from theoretical point of view (and I can't argue and don't want to) but apparently not always very bad sound for everyone in fact quite the contrary - quite a good sound for many, isn't it? those Grand Scepters also won international acclaim and many prizes worldwide so perhaps the ideas were indeed very bad (who am I to argue?) but sound apparently not so bad at all though best, graaf
The idea has its genesis in the matrix circuit for the FCC approved Zenith method of frequency division stereo demultiplexing |
#3338 |
graaf,
Irritants don't always produce pearls. |
#3339 | |
The Summa waveguide does not go down to 800 Hz and it would be way too small at that frequency. If you buy into "international acclaim and many prizes worldwide" as a testiment to good sound quality then you are pretty nieve about how those accolades come about. It sounds a little like Lynn and I were being baited into an arguement here. If you already liked those speakers so much then why did you ask my opinion of them? If I thought that was the way to go then I would have done my speakers that way. |
#3340 | |
are You irritated?
| Page generated in 0.19267 seconds (70.79% PHP - 29.21% MySQL) with 11 queries |
