#3011 |
Banned
#3012 | |
Banned
Lay down the law on compression, mixing, frequency response, miking and mastering techniques, ect... - use the license money to promote the quality of the playback, deeper music appreciation, ect. and educate people on the benefits of high quality music playback If there is a will there is a way! |
#3013 | |
..and you would be correct, I was wrong. http://www.audiocircle.com/circles/i...&topic=49585.0 Clearly from that 2nd picture its a dipole. I'm guessing what that forum isn't getting is the concept of polar rotation. I don't think though that it has anything to do with corner loading per se. (..though again of course I always could be wrong.)
perspective is everything |
#3014 |
Lynn ... Jensen suggested this for my UB waveguide. http://www.sicaspeakers.com/12K3.pdf
Looks good for OB if not too stiff. Not as efficient as I would like, but beggers ... Zene |
#3015 | |
Banned
Jorma Salmi is a designer who knows what he is doing (near top IMHO). Not sure why he wouldn't use a coax for MT, but I'm sure he has his reasons for that particular design. The polar opposite of the brain dead designs that make up about 95% of speakers I see pictured at the show (that Audiocirce site had a ton of pics). Some of them sure look pretty enough to sound good to audiophiles though.cheers, AJ |
#3016 |
Hello all, This is a little late, but I've been out of town for 3 weeks. About 30 (or so) posts back cone tweeters were mentioned. I've been listening to them for over 40 years and I like them over domes, but it's hard to find any new ones. I prefer open back for dipole use. Anyone know of a source other than e-bay or the thrift store?
"Whenever you find you are on the side of the majority, it is time to pause and reflect." Mark Twain |
#3017 |
Location: Austria, at a beautiful place right in the heart of the Alps.
Hi
The topic of Doppler genererated intermodulation distortion is something pretty interesting and I adopted my earlier spreadsheet with the functionality to import and process any measured or simulated speakers. Exported data of the beautiful simulation software "Hornresp" from David J McBean can be imported almost directly. ![]() http://members.aon.at/kinotechnik/di...distortion.xls Now its very simple to check open baffle against closed box or horn and wave guide. Have fun ! Michael
Audio and Loudspeaker Design Guidelines |
#3018 |
It seems like driver selection is still way up in the air. Why not put these into the mix...
http://www.harman-japan.co.jp/produc...me/1500al.html http://www.harman-japan.co.jp/produc...ome/435be.html http://www.harman-japan.co.jp/produc...e/ut045be.html They aren't really cheap, or even affordable...but they probably sound nice. C |
#3019 |
The 435Be is the most interesting of all, and there is no direct equivalent - the process TAD uses to form their Beryllium diaphragm is different (vapor deposition vs JBL's preformed sheets). I'd still use a Tractrix or LeCleac'h waveguide instead of JBL's horn, though - BiRadial horns are optimized for coverage, not impulse response.
Good article here on the development of the 435Be. The sonic inferiority of Titanium diaphragms compared to Aluminum is discussed with refreshing frankness, along with the surprising admission that "both aluminum and titanium compression driver diaphragms are in breakup for much of their response". Diaphragm breakup means high distortion, chaotic wavefronts coming out of the phase plug, and non-minimum phase FR deviations - all bad things. To examine one point alone, if the diaphragm is in breakup, that means different portions are out of phase with each other, instead of emitting coherently. This invalidates the underlying design assumptions of the phase plug, which in turn means that the wavefront emerging from the phase plug is no longer coherent and uniform. If the wavefront isn't uniform entering the horn, it will certainly be in much worse shape by the time it leaves the horn with additional diffraction artifacts added in. Thus, a frequency response with many small deviations, polar response with narrow artifacts, and time response that takes a long time to settle to zero. All from diaphragm breakup. I'll grant that soft-dome tweeters are in breakup over much of their range as well, but that's a bit different - the damping goo spread onto the silk dome diffuses the resonances into a very fine-grained pattern, and there is no phase-plug assembly and horn to magnify small departures from coherent radiation into big ones. And it's no secret that pushing a soft-dome tweeter into 100+ dB SPL's is not a good idea from either a distortion or longevity standpoint. |
#3020 |
Gentlemen,
I don't recall seeing center speakers discussed in this (lengthly) thread. I would like to spread out my OB speakers for furniture placement reasons. What are the pros & cons about using a center OB speaker? If it is a reasonable addition, I remember(from my younger years)there were various ways to wire it, all with different disadvantages. Any wiring suggestions? dobias |
