Beyond the Ariel
Although restrictions on my travelling prevented me attending this year's "Tube Tasting" at Oswald's Mill, John Atwood did go, as you can see from the ClariSonus link. He reported the OMA "house speakers" at the Mill used RAAL supertweeters, vintage RCA MI-9584A compression drivers on wood conical horns, and Altec 515 Alnico woofers - and the sound was superb.
Granted, I didn't hear the system for myself, but JA has pretty good taste, and I take his report on the sound quality seriously. By contrast, if some reviewer I don't know says XYZ speaker sounds wonderful, that doesn't mean anything, since I've never heard their own system, their choice of music, or what they think is good.
So the selection of a RAAL, new/vintage compression driver, and Altec direct-radiator bass isn't as zany as it might seem - the folks at OMA have already gotten there ahead of me. I'm doing it with a little different spin, and a lot of reliance on Bjorn Kolbrek, Martin Seddon, the good folks on this forum, and MLSSA.
I was told Tom Danley's PA speakers blew the "ribbon horn" away. Hmmm - Suppose we all have our preferences
Here is a TAD loaded horn and the sweet sounding RTR electrostatic tweeters LOL -not quite ribbons, tried that too
Well, everyone at the Tasting probably came away with different impressions - tastes differ, especially in the horn-enthusiast arena. Many of them do not seem to hear horn-colorations at all, or if they do, they don't consider it a coloration worth bothering about. Other folks are extremely sensitive to this sound - Karna and I fall in this category. JA is pretty sensitive to this coloration, but not as far out on the bell curve as I am. My tolerance for time-domain colorations is pretty low - all those years of working with allpass filters and fiddling with crossovers might be responsible. Then again, Karna hears this stuff right away, and objects in stronger language than I use.
So without personally knowing the participants, well, I have no idea what they were hearing - I can't even guess. I've been to plenty of demos where everyone else was absolutely thrilled with the sound, and my reaction was "ho-hum", mild annoyance, or an outright dislike. But nobody is making me listen, so I leave as quickly as possible if it isn't going well. No point in spoiling everyone else's party.
Where it gets really uncomfortable is when I am asked to state my reaction after one of these events - I still haven't figured out a way to lie diplomatically. I know, I have no future in politics or international relations. And my father was a US Foreign Service diplomat, too - maybe it's my great-grandfather (a radical priest who left Sweden for America) that's doing the talking. Karna's grandma and grandpa were Norwegian, and she's got the same kind of directness that I heard growing up.
Well they are both conical horns but one is rectangular goes an octave or two lower and higher, is nearly perfect in phase and from what I hear if it'd go lower it's pass a nearly perfect square wave - not bad for PA horns! - colored - probably, but from what I've heard of DIY Danley conicals I'd say very low coloration.
I've played with that method too and found that's pretty close to the real case:) (in my own limited experiences of course)
I'd put the mic higher, near listening position, though.
Oh, you may also find in such cases that widening the baffle provide much more bass extension than making it higher...
LineSource said:
...Playing with the EDGE baffle simulator see if floor effects are properly modeled by mirroring the design..does this look correct??
You are talking about floor effects (plural).
What you are simulating now is "floor gain" exclusively. The other important effect is "floor bounce". To simulate that properly you need to put the mic higher (as CJS already stated) and look for the applicable mic distance.
Try different distances, ranging from 2 to 5 to 100 meters, to get a feel for the power radiated into the room.
What makes estimation of bass difficult is the perceptual model for the ear shifts from dominance of the direct-arrival sound (above 300 Hz) to perception of the overall power in the room (below 300 Hz). This is why it is an industry convention to "splice" the frequency response at 300 Hz, using direct-arrival MLS/FFT measurements above 300 Hz, and near-field measurements below that.
Nearfield measurements are simple for a closed-box loudspeaker (put the microphone about 1" away from the cone). Nearfield measurements for vented, TQWP, and transmission-line systems require the additional step of ratioing the area of the vent to the area of the speaker-driver. As far as I know, nearfield measurements do not give valid results for dipoles and quasi-cardioids (dipoles with acoustic fill in the rear), since the interaction with the room is so complex and unpredictable - it's no longer a simple matter of total power radiated into the room, as it is with a monopole loudspeaker.
Given the challenges with measurements, that makes it difficult to accurately simulate what the in-room results at the listening position will be. The Edge simulator assumes free space - literally, a loudspeaker baffle and microphone hanging in mid-air, far above the ground. By mirror-imaging the virtual loudspeaker below the real loudspeaker, you are moving Edge to the ground - say, a flat expanse of concrete, extending hundreds of meters in all directions.
What remains unsimulated is the listening room, which most certainly will affect bass below 300 Hz. (There will be more bass than the free-field condition - the question is, how flat and how much.) Perceptually, the direct-arrival wave starts to merge with all of the many reflections arriving from the room boundaries - walls, ceiling, and floor. Since the wavelengths are long, the phases of the individual reflections has a direct result on how they will sum at the listening position - that is, you have add the power of each reflection vectorially, not just the power sum (which is more appropriate at higher frequencies, where the phases of the reflections are randomized).
Absorption by carpeting is well under 1 dB at low frequencies, so all surfaces can be assumed to be rigid - with the following restriction: in wood-framed houses in the USA, Canada, and other parts of the world, the flexure of the wood framing results in bass losses due to sound going right through the wall. This happens mainly below 50 Hz, and is the reason your neighbors may hear more deep bass than you do. Large glass surfaces also leak bass at low frequencies. Openings into other rooms - doorways, hallways, open-plan architecture - all make the model even more complex - in the limit case, you might have to model the entire house. Gary Pimm, for example, found (by measurement) that the LF limit of his cardioid-bass system was determined not by the size of his living room, but by the dimensions of his house.
Off Topic...but maybe not.
All,
I visited the West Coast Shindo dealer yesterday and was able to hear a full Shindo system including the Latour speaker. It uses a field coil version of a vintage Altec 288, a field coil version of a vintage Altec 515, and a modern interpretation of a Westrex 80/20.
I have heard a many hifi systems over the past decade or so and relatively few if any music reproduction systems. Yesterday I heard the finest music reproduction system I have ever heard. The qualifiers being the following:
After a few notes I stopped listening for the audiophile stuff like imaging, soundstaging, detail, extension, resolution, colorations, etc...and was simply drawn into the the performance in an engaged emotional experience. This is something that has never happened outside of live performance. That being said, all of the audiophile stuff was there and none of it drew attention to itself screaming "This is memorex."
Since this thread has run the gamut on material covered, I felt it was as good a place as any to pass along my thoughts,
Chris
It is vented. There were several slot shaped ports on the bottom. I don't think it is traditional BR loading or even TL....more like the kind of alignments that were done before Theil and Small made things easier. At that time, people experimented, listened, and figured out what worked. I think it is probably something more like that.
Re: Off Topic...but maybe not.
chrismercurio said:
All,
Chris
I am not so surprised. There have been times when large-format, Alnico-magnet Altec speakers have sounded - for lack of a better word - "magical". It's not really magic, of course, but subtle aspects of the Western Electric engineering approach that persisted in the Altec organization. Not all aspects of driver construction are written down in spec sheets.
I find it significant that Altec engineers resisted strong corporate and THX movie-industry pressure to change over to higher-power titanium diaphragm drivers, on the grounds that titanium just didn't sound as good. A decade later, with Altec no longer around, JBL quietly admits that aluminum sounds better - after the rest of the prosound industry has converted over to titanium. By then, of course, beryllium was the New New Thing, so everyone started chasing the latest wonder material. Hmm ...
Reminds me a bit of the huge PR campaign in the early Eighties to promote 44.1/16 PCM Compact Discs as "Perfect Sound Forever". A few people still buy into the propaganda that 44.1/16 sampling represent the limits of human hearing. But - when the Red Book patents for the Compact Disc expired (and not before), what was waiting in the wings?
You guessed it - higher-rate PCM with much greater bit depth (more resolution). That would make 96/24 and 192/24 "Better than Perfect Sound for Longer than Forever". The really interesting thing is that BtPSfLtF sounds like - analog mastertapes!!!
Re: Re: Off Topic...but maybe not.
Lynn Olson said:
Reminds me a bit of the big PR campaign to promote 44.1/16 PCM Compact Discs as "Perfect Sound Forever". When the Red Book patents expired (and not before), what was waiting in the wings? You guessed it - higher-rate PCM with much greater bit depth (more resolution). So that would make 96/24 and 192/24 "More Perfect Sound for Longer than Forever".
I still like records. It doesn't matter if it is a Shindo'd 301 or a Technics 1200.
Chris
