Beyond the Ariel
I wouldn't be shy about separating things - don't forget small winglets on each side of the baffle quite substantially increase baffle area - see the baffle by Magnetar referenced a few pages ago.
As mentioned by Magnetar and in the JBL brochure, you are free to independently lowpass filter each woofer - one can get wideband sound up to the tweeter crossover, while the other gets lowpassed at a much lower frequency (two octaves lower). If you take this approach, I'd put the HF radiator directly above the wideband woofer, otherwise the radiation pattern at crossover will be tilted sideways (as it must be in the JBL).
I concur with Salas' suggestion of a slight angle between the paired woofers, similar to what JBL is doing, if you want a side-by-side pair. In my baffle, it gets a little awkward because I want another driver(s) directly above the close-to-floor-mounted pair, and all those conflicting angles makes for a weird and hard-to-build baffle.
A quartet of 12" drivers (my favorite 12NDA520's or similar) mounted on a pair of hinged baffles with a slight (15 to 30 degrees) inwards bend should work fine, with the HF driver mounted directly above the widerange driver closest to the center of the soundstage, and the other top driver lowpassed two octaves below the widerange driver. Both the widerange driver and the HF driver should point inward - I like the old BBC method of crossing the pair at a point about 1~2 feet in front of the listener.
As per the previous discussions, the two drivers closest to the floor have their own amplification and EQ, matching them to the room and complementing the dipole rolloff of the upper set of drivers.
The radiating area of four 12" drivers is about equal to the five 10" drivers used in Magnetar's setup, so there should be plenty of dynamic range. Small side wings similar to Magnetar are probably a good idea as well, although I'd certainly cover the wings with several inches of recycled cotton fill, and possibly fill the semi-enclosed area between the woofers as well, to decrease standing waves, move the radiation pattern closer to a quasi-cardioid, and gain a bit of LF extension.
I think it can have good base for floor contact, get narrower, and go deeper, if done like this.
Right Angle
Gentlemen;
Thank you for the responses. I now have my work cut out for me.
Since I have to buy a few more of the same woofers on eBay, that could take some time & patience. In the meanwhile, I'll rework what speakers I have into Salas' recommended arrangement.
I'll report back with my impression of the results.
In my former life I was an industrial troubleshooter & inventor. I had a vast array of test equipment & experts at my disposal, including sound meters. Now I'm reduced to trusting my ears!
dobias
I think the 18 sound driver has too low of QTS. It may not go as low as you want without EQ, then if you boost the bass you have to look at it's limited xmax.
When using a pair of woofers I found two 21" drivers (.7 QTS) was good, but not as good as 5 or 6 high qts 10's. The tens sound free from the box, or more realistic if you keep live music sound as your perspective. The 12's may sound free too. Free- when listening to live music bass has a homogenize sound that floats through the room into your body without a sense of 'bass' hifi sound or reproduced sound through a loudspeaker system. This character is very difficult to achieve , even with bass horns. The dipoles will do it! I beleive the dipole radiation and lack of box colorations is the reason BUT you need to be able to move a lot of air too with out compression or distortion to distract your free feeling.
Are you saying you will use four 12's in the bass with one pair running up higher than the other? How would you crossover / drive this quad?
I also high pass my bass drivers- this lowers the movement in the bottom octave and increases the dynamic range. It really cleans things up. 50 cycles seem to be the best place with the 10's.
Right Angle
Magnetar,
Perhaps I didn't explain my set up sufficiently;
Each Wharfedale speaker assembly starts with a full range 12 CS-AL, no crossover.
The first augmenting woofer has an air wound 4 mH coil in series for a 280 Hz low pass.
The second augmenting (& the future third) woofer add another 4 mH coil for a 140 Hz low pass.
I've tried using a subwoofer to reenforce the bass and it only muddied the sound.
Using the amplifier's bass boost seems to ruin the bass quality.
After I get the additional woofers & build the appropriate baffles, I'll try high passing the woofers as you suggest. I have no clue as to the woofer's Qts or xmax. Wharfedale's factory burned down many years ago destroying their records of the old speakers.
I now have augmenting Super 3 tweeters aimed up. I plan on adding second Super 3's aimed to the rear. They are high passed at 5,000 Hz with 3.9 mfd.
Thanks for your interest.
dobias
Lynn,
I don't get the attenuation of the rear wave creating a cardioid response. Attenuation changes toward monopole, but if you're talking about low bass attenuation is difficult. An OB radiation pattern changes from dipole toward cardioid using the baffle structure. The area of greatest null (sides for dipole, rear for cardiod) occurs where the front and rear waves have traveled the same distance.
Also note that I've found that changing the radiation pattern has less effect sonically than you'd think, however, it does seem to affect the "live" sound that Magnetar mentioned, and placement combined with radiation pattern plays a big role in my narrow room. Dipoles are more "live" with near side wall placement, but they need to be well out from the front wall (2m+). My U-baffles with a dispersion change toward cardioid sound more "live" if placement nearer the front wall is needed.
With OB the room really is an integral part of your speakers, so optimum results will require tailoring your baffles specifically for your room. The beauty of OB is that test baffles are easy and you can make changes on the fly. You can even get away with McGyver type stuff using duct tape and scrap wood.
It's going on 7 months now, so it's time for actual building to become part of rehab. The rest of the guys have no excuse for not actually having built anything during this thread. Hands on experience is so important with OB, and that's what has enabled Magnetar and myself to hone in on our goals.
Happy building,
John
Right Angle
Gentlemen;
After relocating woofer #2 from it's right angle mount at the rear to the front firing location, I'm amazed at the improvement. I have the woofers turned inward by 30 degrees, but find it difficult to say it's much better than having them parallel to the main baffle.
What's most satisfying is the present ability to use the amplifier's bass boost (5.5dB) without coloring
or smearing the bass. I haven't tried stuffing anything behind the woofers yet.
I'm still perplexed by the ability of the 'columns' I have at the sides of the main baffle to improve the soundstage.
They're 4 1/2" OD carpet rolls made of heavy cardboard. I had taken a 1 1/2" slice out of the sides to fit them over the main 16" x 32" baffle. That leaves over 1 3/8" of the column sticking out in the front as well as the back. I would expect that would present an obstacle for the sound waves traveling across the baffle. If that reduces the streamlining of the corner, I sure can't tell! Removing the cardboard tubes shows an immediate reduction in the soundstage. With the tubes in place I can hear the soundstage widen by a yard or more to the outside of the two speaker baffles.
Rather than facing a sidewall or an endwall, my TV is across a corner & the speakers are spaced out & to the sides of the TV view. I know that is unusual but I find the stereo imaging to be superb. I'm planning on having the 'proper' rounded corners on the final setup.... still, I can't help but wonder if there isn't some benefit with the columns as they now are.
dobias
Hi Dobias,
When I used carpet rolls beside a baffle they were three turns of thick carpet but no internal tube. Overall diams between 9 and 12".
I started with them symmetrical (like fig-8) but ended up rolling them backwards to widen the front angle and close the rear.
I also fitted a single carpet layer like a cabinet top over them supported by expanded metal grille.
Reproduction was nicely damped, but I've no room for them on a permanent basis.
(Wife would prefer something as thin as a drainpipe!)
Cheers ........... Graham.
johninCR said:
Lynn,
<snip>
Happy building,
John
"..rest of the guys...not actually having built anything during this thread..."
Say what?? I've built several, and still continue tweaking...post 2471 of this thread for instance...
...not to mention post 21 here...
http://www.diyaudio.com/forums/showthread.php?s=&threadid=110583
I s'ppose, since I'm not using "full range" boutique mega$$$ cone drivers (which seem to be all the rage here) and have achieved excellent results with the dreaded "wispy, fizzy, etc." planar magnetics many folks appear to hate, nor do I have any commercial credentials (or agenda) in the audio field, none of this work qualifies...
Oh well, not my loss, I'll just continue to listen to the incredibly lifelike full range dipole linesource sound I've achieved after 39 years of building horns, subs, OB's, PR's, etc ...😀 😀
John L.
In Praise Of Shadows
As a brief interlude may I offer up the following taken from Junichiro Tanziaki's luminous essay "In Praise Of Shadows', written during the late twenties:
And had we invented the phonograph and the radio,how much more faithfully they would reproduce the special character of our voices and our music.Japanese music is above all a music of reticence,of atmosphere.When recorded, or amplified by a loudspeaker,the greater part of the charm is lost.In conversation ,too, we prefer the soft voice, the understatement.Most important of all are the pauses.Yet the phonograph and radio render these moments of silence utterly lifeless. And so we distort the arts themselves to curry favour for them with the machines. These machines are inventions of Westerners, and are, as we might expect,well suited to the Western arts. But precisely on this account they put our own arts at a great disadvantage.
Cilla
Hi
Magnetar, how did you arrange all these 10"s? Any additional sub below 50 Hz used ?
Greetings
Michael
I have just looked at the RAAL website and from all the posted comments there this one specially caught my eye.
Being a long time user of RAAL ribbons, I have always had considerable problems which are probably going to keep coming up in the future. It has been very difficult to find an adequate partner for them, be it mid-bass or mid units. More or less, only custom built loudspeakers can match these extremely demanding ribbons. With every new project, I face the same time consuming struggle. It often happens that, while listening to other systems without RAAL ribbons, I have to ask: “Excuse me, but are your tweeters working properly?” These ribbons are not capable of hiding or diminishing anything at all. You are able to hear the details from the recording that recording engineers certainly don’t want you to hear. Way to go, Alex! Keep revealing the truth to us in the future!
That's exactly what I'm a bit afraid off, too find a good match for them. I really don't know how they compare to the Raven or Aurum Cantus ribbons in terms of body at the lower end of the spectrum but what I have found very difficult with them is the match to the midrange. These ribbons are fast, very fast. Combining them with a midrange is difficult. Anyone out here who has tried them at home for a longer period of time in compare with other ribbons.
A *good* compression driver or *maybe* a pair of PR170MO Audax. IMO a good compression driver will eat it up dynamically though. The ribbon may fail if you want to keep up without compromise-
Here is a speaker system I built with the G1 - The owner (very particular audiophile) LOVES them. The bass is a straight horn loaded with EV 15L and the mids are the 16 ohm JBL 2123J's , series network, first order crossed around 1.6K - the tens were used because they went lower than the Audax and have much higher sensitivity. At the time the owner had 45 amps - They seem to keep up fine for him. The JBL is not your run of the mill driver.
augerpro said:
Lynn how do you plan to get a hold the 18Sound 8NMB420? The info I'm getting is the US distro is not importing those or the 6NMB420, both of which I'm trying to get a hold of for testing. Any help or advice would be greatly appreciated.
A friend of mine and I purchased 4 of the 8NMB420's last month from Universal Music LLC in Miami, FL.
No problem, he called them with a credit card number and they were on a truck in two-days. I don't know how complete the inventory is, but they've got the 8NMD420's 🙂
Edward
