I am looking for the best pure midrange (~400hz to 1500~2000hz, final passband is dependant on integration with compression driver) solution. This speaker is meant for subjective listening excellence and will be a substitute until I have time to truly sit down and engineer my ambitious ESL project. I listen to a lot of progressive metal (ie TOOL, Dream Theater, NIN although they arent quite in the same genre) which in themselves introduce large amounts of favorable distortion. I do NOT want the speaker to rip these recordings to shreds, remember this speaker is meant for listening enjoyment. I do not have a price limit, although a large increase in price for marginal improvement is hard to justify. The PHL 1120 look excellent ($120 at Zalytron), but would something lk an 18sounds 10NdA520 ($225) or 10NdA610 ($238) which possess AIC (Active Impendance Control) be a much better solution? I will be tri-amping with large proamps and am considering a PC XO for DRC and FIR filters if I can get the software cheap enough. I will be crossing to a BMS 4540ND (have not decided which waveguide I will be mating with it) on the topend and a Ciare 18.00NdW1 on the lowend (exhibits the first breakup node between 1600-1700hz, so 3rd harmonic of this peak should lie smack dab in the 500hz range, 530-570). A high efficiency driver seems like an obvious choice since it will be used between two of them. |
#2 |
PHL1120 has not quite a good CSD.
Have a look on this thread, many references have been mentioned. Searching for an excellent midrange...
Fostex F120A speaker pair for sale - 250€ only ! |
#3 |
It was not mentioned in the linked thread, have a look at the Ciare 10.64 NdMR. It is a pure midrange (fs 141Hz) with >97dB above 400Hz@2.83V. A little resonance at 2.3kHz, but even at that frequency a very fast decay. Harmonic Distortion <0.3%@90dB for all orders. 243€ in Germany.
Another really good one is the Celestion TF1020, little higher distortion, less SPL (96dB above 300Hz@2.83V), but better dispersion than the Ciare. Only 92€ in Germany. Baseballbatboy |
#4 |
What kind of SPL are you looking for?
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#5 |
This depends a LOT on what type of sound you want..
1. Obviously you want details (to compete with an esl), THAT suggests a high eff. driver (for its sd). 2. IF you want something that presents a more "holographic" sound then look for a low mass driver (for a given sd), AND a relatively small sd. Unfortunately 1 & 2 are at cross purposes, especially if you want high output in addition to 1 & 2. My suggestion will net you all 3 (with a steep high pass), and you can impove upon the decay character somewhat with some driver modification. FE126E X4 per side connected in series/parallel. This will "lift" the response around 480 Hz or so to compensate for the loss in spl the driver naturally has (..and as a result should give a moderately flat freq. response in your intended passband). I'd recommend open baffle to get the best sound with the least work. Use the "Edge" software program to get a good open baffle configuration. Note that the FE126E even with modification has a modest problem just above 1 kHz.. BUT that doesn't seem to deter people from liking the driver. For a moderately unbiased subjective opinion read Troel's comments here: http://www.troelsgravesen.dk/FE126E.htm Contact Dave (Planet10) for details on driver modification if you are interested. for the horn - take a look at Paul W's MusicSupplyCenter waveguide here: Large midrange for OB??? Scott G ?
perspective is everything |
#6 | |
Those drivers seem interesting ! Do you have the links to the complete tests of these units ?
#7 |
I want a sound that best compliments the type of music I listen to (Progressive metal, ie TOOL), not necessarily micro details.
I read the entire large midrange for OB thread and am extremely curious on the use of the 18sound 15ND930/18ND930 (or other extremely large diameter drivers) in the upper range. How would a driver like this compare to a dedicated midrange? |
#8 |
Here's the link to the PDF of the Celestion TF1020: http://professional.celestion.com/pr...pdf/TF1020.pdf
The frequency response and the impedance are nearly the same as the one in the german magazine Hobby HiFi, so I think you can trust them. Maybe I can give you a scan later, but don't expect too much, my scanner is lousy and the distortion graph does not have much contrast. I can give it a try. The Ciare is in the same test. Here's the pdf, again the frequency response looks like in the test (although its a little bit louder): http://www.seeburg.net/1064NdMR_dt.pdf Baseballbatboy |
#9 | |
#10 | |
| Stereo Lab 400hz 1" horns | winslow | Swap Meet | 14 | 21st July 2009 10:40 AM |
| pure midrange W18E or PR170MO on open baffle? | thadman | Multi-Way | 20 | 19th March 2009 06:31 PM |
| Hey Dave hows the FF85K OB at 400hz.....? | speakrsrfun | Full Range | 37 | 27th January 2009 03:46 PM |
| Is the Peerless SLS263 (10") clean up to ~400Hz? | Virtalahde | Multi-Way | 5 | 1st July 2006 09:35 PM |
| Page generated in 0.12505 seconds (80.47% PHP - 19.53% MySQL) with 11 queries |
