#21 |
Ah gosh folks, I'm new here but how can you comment on anything other than aesthetics without listening to them?
#22 | |
After designing and prototyping for a while you get a "feel" for measurements and the resulting sound. Its an art form based on science. Also, you are typically exposed to many of the drivers (or VERY similar variants) in use, (..perhaps not purchased, but rather listened to in other designs to see if you even want to contemplate purchasing the drivers). For instance I for one do NOT like the "base" sound of the Danish ring tweeters in use in this design. They have fairly good clarity.. but I find the sound they reproduce, (in several designs both expensive and inexpensive), artificial at best. And by "artificial" I mean 2d as opposed to 3d, (not so much with regard to image location but rather image presentation), and compressed in sound (..which isn't a surprise considering the surround is the diaphragm). Additionally, the lack of top octave response off-axis I find very noticeable, but then I hear rather higher in freq. than most males (..and its VERY annoying walking into stores with crappy lights).
perspective is everything |
#23 | |
Also the implementation is week in this design. (..at least for a typical in-home setup.) Consider that the midbass driver's he is crossing over to aren't beaming significantly at the crossover (only marginally). Also the waveguide is quite shallow and effects a relatively small passband. The transition then within a 60 degree window is moderately flat at 2 meters, BUT still exhibits a dip in response as an average near the crossover region. IF the designer is looking for a flat freq. response in this listening window then he has "missed" it.. However.. I think the reviewer basically nailed this design - its STRICTLY a control monitor for mastering recordings. i.e. designed for almost near field listening, less interference from console reflections due to the mtm, flat response, etc.. I also wouldn't be surprised if the speaker's linear decay was pretty good.
#24 | |
I'm not sure I understand what you mean with "adjusted." I sort of know what you mean. But what impressed me about the Dynaudios is that they measure much better than the other ultra high-price speakers, like the Mårten Design Coltrane, reviewed by Stereophile. So if the Dynaudios are adjusted (as in looking better?), how "bad" then are the other speakers? |
#25 | |||
#26 | |
"Dynaudio Temptation, anechoic response on axis midway between the two tweeters at 50", averaged across 30 degrees horizontal window and corrected for microphone response, with the complex sum of the nearfield midrange, woofer, and port responses plotted below 300Hz." I'm not particularly enamoured of Stereophiles reviews, but I think JA does a good job of measuring stuff. I do think he takes too much time trying to justify the short-comings he might find in his measurements, though.
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#27 |
there's a lot of talk about these speakers, but has anyone actually HEARD them?
i have, a couple of times. they do sound good, and very neutral. however, they are absolutely lifeless and not involving at all. after a couple of minutes, they just bore you. plus, they lack dynamics and speed (where are those graphs) they have the same problem most high end speakers have. they had a designer who thought throwing tons of money at a design would make it sound better. so he thought of the most expensive way to make a cabinet. well, it is pricey, but it doesnt look very nice, and it doesnt sound good either. for the price, the thing looked bad. the joints werent all that well done, the finish was poor, and they just looked boring. are you guys surprised? its just another overly expensive cabinet, off the shelf drivers, and a ridiculous claim. i mean, how many of these threads do we need? yeah, another guy thought he was the audiophile's gift to loudspeaker design and he was wrong. this happens daily in the audio world. |
| "Dainty" loudspeaker parameters. | ashok | Multi-Way | 24 | 26th December 2012 05:48 PM |
| "compact loudspeaker factory visit from "magico mini" thread | Nanook | Multi-Way | 2 | 4th January 2008 07:30 AM |
| what makes a loudspeaker "full range"? | kneadle | Full Range | 25 | 15th April 2005 07:53 PM |
