Hi
I try to calculate series notch for Eton 5-880 use this calculator http://www.lalena.com/audio/calculator/seriesNotch/ and build calculator in X-over3Pro. Two way to calculate one with only two parameters Re = 6.6 Ohms fs = 6500 Hz output part list Capacitor C = 4.62 uF Inductor L = 0.12 mH Resistor Rc = 6.6 Ohms other way with more parameters Re = 6.6 Ohms fs = 6500 Hz Qes = 0.46 Qms = 2.29 output part list Capacitor C = 8.07 uF Inductor L = 0.07 mH Resistor Rc = 7.925764192139738 Ohms Why in this both way Capacitor and Inductor so different? what way is right? If second way with using Qes Qms parameters is right, how to calculate notch for tweeters, most of them have not described Qes Qms in manuals? One more question If I calculate notch for woofer with compleate parameters Re fs Qes Qms, if I use two woofers in parallel how change Qes Qms?
#2 | ||
| Visaton FRS 8 M Parallel Notch Filer Design | swin1 | Full Range | 13 | 22nd October 2009 10:21 AM |
| Notch filter for Zaph's B3S design | 454Casull | Multi-Way | 1 | 6th May 2009 01:08 AM |
| Notch Filter Design | ChocoHolic | Subwoofers | 36 | 13th October 2007 04:25 PM |
| Active Notch Filter design needed | Vikash | Multi-Way | 63 | 21st May 2007 05:14 PM |
| Zaph's L18 design, notch filter---Do I miss something? | Jay_WJ | Multi-Way | 21 | 11th April 2007 04:30 PM |
| Page generated in 0.07421 seconds (69.23% PHP - 30.77% MySQL) with 10 queries |
