Old 15th April 2007, 12:33 AM   #1
theAnonymous1's Avatar
Question Alternatives to the Silver Iris?
I recently bought a pair of 15" Silver Iris coaxial drivers, but I'm less than satisfied. While they are very good sounding drivers, the mid-bass is just too muddy for me. I think this is due to the high Qts.
What alternatives are there that have a lower Qts? How about the BETA-12CX or BETA-10CX? I can't really find any reviews on how they sound.
Anything else in the $100 per driver range?
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 15th April 2007, 12:42 AM   #2
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
You might consider using the SI woofer as a bass augmenter with just about any fullranger on top to get the mids you are after. In one of my alignments, I use them as a 2-in-1 speaker. Fostex FE108's on top with the SI woofer for bass fill with just a 1st order filter. Then for loud listening, I flip 2 switches to cut the 108's and kick in the big coax with it's tweet using that stock XO.
Everyone has a photographic memory. It's just that most are out of film.
Old 15th April 2007, 12:54 AM   #3
I like the idea of a coaxial for the mid-bass/mids/highs and I already have 4 15's for bass duty. I'm just looking for another coaxial that has tighter mid-bass. It doesn't need to play very low. Flat down to 100hz is good enough for me.
How does the midrange of the BETA-12CX sound? I see the cone doesn't have any...ummmm, ring things (brain fart, can't think of what their called).
Old 15th April 2007, 01:03 AM   #4
Can't you lower Q by putting a resistor across the terminals? Also, are you filtering the bass frequencies away from the coax woofer? Playing low frequencies always seems to muddy up the mids to me.
Old 15th April 2007, 01:57 AM   #5
JandG is offline JandG  United States
I would cut the bass off that coax..@ 150hz or so..go active on those 4x15 " & then tweek it from there. If I had the Silver Iris I would use something line level or just complete active. Plates & something active for the fullranges & ability to bring in a tweeter of choice. JohninCR is lucky with his speaker mangement system. Extremely flexible. Vintage Alnico coax might be a good bet also as super high Qts is of not much consern if you go active bi-amp with plates or whatever. Alnico has a major tone differance to me for the good in the low mids & mids. yep I would go vintage.. or work that Iris over..
Old 15th April 2007, 02:22 AM   #6
I have a full active setup, 6-channels. The SI's don't have the help of the 4 15's yet. I still need to finish(start) their ripole cabs.
Maybe I'll try high passing them even though I don't have a bass setup yet. I still think they will be missing that "snap" I'm looking for.
I would still like to know how the BETA-12CX would stack up against the SI.
Old 15th April 2007, 03:31 AM   #7
Maybe Darrel will switch your old ones for the new 10"ers. BTW how big are your baffles? I understand that the bass gets a bit heavy if the baffle is too wide or the drivers too close to the floor.
mike
Old 15th April 2007, 03:38 AM   #8
mpmarino's Avatar
I wouldn't recommend the 12CX for hifi .. Please note I've only used the psd2002 compression driver. Maybe it could be quite better with another tweeter.?
I have a bit more info if you'd send me an email...
Crazy Yankee.
Old 15th April 2007, 04:16 AM   #9
holdent is offline holdent  Canada
What are your baffle dimensions and where have you located the SIs on them? Your experiences don't match mine with the SIs and I suspect you have a baffle problem not a driver Qts problem. Try a 18 x 38" baffle with the driver at 21" up from the bottom. This is where I found the best balance. As well OB speakers are sensitive to positioning - make sure they're more than 1 m out from the back wall.
For me the Hawthorne Silver Iris' produce a great open relaxed sound. They are even better with an additional 15" woofer to augment the bass. I couldn't afford Hawthorne's Augies but I very happy with the less expensive Eminence Alpha 15As.
Old 15th April 2007, 07:07 AM   #10
jrd is offline jrd  United States
( Can't you lower Q by putting a resistor across the terminals? )
John:
Do you know how to calculate the new Q with the parallel resistor?
TIA,
John
Hawthorne Silver Iris - New OB driver johninCR Full Range 36 10th August 2008 03:05 PM
sterling silver iris's kesa32 Full Range 12 29th December 2007 03:25 AM
Silver Iris pair for sale. castlesteve Swap Meet 4 9th October 2007 12:32 AM
FS: A pair of Silver Iris Speakers. rca9449 Swap Meet 6 15th June 2007 01:21 PM
Silver Iris OB Project... chops Full Range 6 27th January 2006 04:03 PM
Page generated in 0.09389 seconds (86.71% PHP - 13.29% MySQL) with 11 queries
