Simple question on multiple port lengths
Old 17th January 2003, 08:13 AM   #1
Dave Bullet is offline Dave Bullet  New Zealand
Default Simple question on multiple port lengths
Assuming the following equation gives the length port(s) in metric:
Lv = (23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv)
(dv=diameter)
Does that mean Lv =
a) the total length of all ports?
or
b) the required length of each port?
eg. if Np=1 and Lv = 45cm for a given Fb, Vb and Dv, but the equation = 97cm when Np=2.... Does that mean each port should = 97cm in length? - or each port should add up to a total length of 97cm?
Also.... does each port have to be the same length (eg - could one be 60cm and the other 37cm - assuming the same diameter)?
Yours in simple minded confusion,
Dave.
Old 17th January 2003, 10:10 AM   #2
audioPON is offline audioPON
Send a message via ICQ to audioPON
I'm not sure about your first qestion, but it looks like it would be the lenght of each port.
Each port needs to be the same length.
Simple question on multiple port lengthsHide this!Advertise here!
Port lengths: which measurement? rajivs Multi-Way 11 30th July 2009 04:55 PM
Port length - multiple ports mashaffer Multi-Way 9 14th July 2006 09:15 AM
multiple port placement.... ChesterFuzzin' Multi-Way 1 17th May 2002 06:08 AM
Simple (hopefully) speaker port question bm_mode Multi-Way 9 25th November 2001 03:06 PM
