Some time ago I built fullrange dipoles using Dayton 15" IB, seas P17RCY and NEO8.
15" lp with 48dB at 30hz and hp with 48dB at 290hz(active crossover) Seas lp with 6db at 290 and hp with 6dB at 1400hz(passive) Neo8 lp with 6dB at 1400hz(passive) Now I'm going to replace the seas 6,5" with Dayton RS-108S-8 7" I've been told that I can't use the same crossovers as now due to ringing from the Dayton 7" at around 6000hz. Would this 12dB crossover at 1000hz work for the dayton 7" and the Neo8?
#2 |
I think that filter would be good enough, especially if you also compensate for the rising impedance of the RS180. Try modeling the crossover using the FRD Consortium Passive Crossover Designer, to see if the cone breakup is attenuated sufficiently.
How about a 1st order slope combined with two notch filters? Simulation Results: Dayton RS180 / Seas 27TBFC 2-way Bookshelf Dan |
#3 |
Thanks!
How would I compensate for rising impedance of the dayton 7" ? |
| Help with filter for dipoles | Mayday | Planars & Exotics | 0 | 14th April 2007 06:38 PM |
| Dipoles ? | LennyK | Multi-Way | 111 | 21st September 2006 03:12 PM |
| Vas, cms, etc... for Dipoles | Raka | Multi-Way | 21 | 19th February 2006 05:43 AM |
| 3-way or 4-way dipoles? | mazeroth | Multi-Way | 0 | 25th January 2006 06:37 AM |
| SPL max and dipoles XLS | Raka | Multi-Way | 11 | 21st July 2004 08:34 PM |
| Page generated in 0.06838 seconds (70.50% PHP - 29.50% MySQL) with 10 queries |
