Old 14th April 2007, 02:10 AM   #1
angeloitacare's Avatar
Default ideas of hornspeaker design
hi all
i would like to present here my ideas of hornspeaker design:
http://fotos.terra.com.br/album.cgi/*1301454:0
any comments are welcome.
rds Angelo
Old 14th April 2007, 03:14 AM   #2
JoshK is offline JoshK  United States
muito bem
Old 14th April 2007, 04:23 AM   #3
OzMikeH is offline OzMikeH  Australia
Volume calculations of the bass cabinet must be tricky.
Curved laminations very time consuming (expensive!) to build.
rounded shape might be acoustically better than a Box.
Your re-styling of another product? what differences other than cosmetic?
It looks like a weapon built by Daleks crossed with an arcade machine. Some people will love it, Some might not. Maybe more timbers to "furniturise" it a little bit or go all out and replace the timber back with lots of little hemispheres then couple it with some of Josh Stippich's (spelling?) very cool amplifiers.
Old 14th April 2007, 07:08 AM   #4
Default re
hi Mike
u are right, it will take moreless one month to make the cabinets.
it will be less expensive than if i would let it make in the u.s. ore europe. craftmanship is not so prohibitively expensive here aroung...
Horns, i am using Orpheans of BD-design, modified bms4592nd coaxial neodymium compressiondriver from 220hz to 22khz, and bass i will use a beyma 15" lx60, tuned to 40hz. it's a own design, and own speaker combination. The main difference to other similar speakers around is the enclosure design.
rds Angelo
looking for ideas (TO-3 amp design) kyleaudio Chip Amps 11 1st February 2008 12:27 PM
Ideas for preamp box design paulspencer Analog Line Level 5 26th August 2006 06:46 PM
Design Ideas kwwitchg Multi-Way 0 8th February 2005 03:05 AM
Newbie design ideas cohort36 Multi-Way 5 18th September 2003 08:59 PM
Page generated in 0.07287 seconds (74.07% PHP - 25.93% MySQL) with 11 queries
