Connectors on MA drivers - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 17th December 2014, 12:37 AM   #1
tomchr is offline tomchr  United States
tomchr's Avatar
Default Connectors on MA drivers
So... I bought my first pair of Mark Audio drivers. I opted for the Alpair 6P. It comes with these connectors, which appear to mate by pushing two flat surfaces together using a soft-ish plastic housing. The clamping pressure of this connector doesn't seem to be very high, so I was wondering if it's needed at all.
Are there any drawbacks of soldering directly to the speaker terminals? I'm thinking to use some AWG 14-16ish zip cord for the connections.
I can't think of any, but that doesn't mean there aren't any...
~Tom
Modulus-86: Composite amp achieving 0.00018 % THD. Damn Good 300B, Novar Spud, 21st Century Maida Reg., Filament Reg., etc.
Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right
Old 17th December 2014, 12:46 AM   #2
Send a message via Skype™ to JonSnell Electronic
None at all, except portability when, you want to move the speaker.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 17th December 2014, 01:09 AM   #3
I throw the connectors away!
Larry
Old 17th December 2014, 01:14 AM   #4
tomchr's Avatar
Well... I would solder the zip cord to the driver at one end and solder the other to a SpeakON connector mounted on the cabinet. The zip cord would be internal to the speaker.
~Tom
Old 17th December 2014, 01:16 AM   #5
chrisb is offline chrisb  Canada
#14 might be a bit thick to fold through the hole in the terminals for soldering- I've never used anything larger than #18 - in fact in most cases #24 solid from CAT5 - yeah, I'm one of those guys
now on sabbatical
Old 17th December 2014, 02:24 AM   #6
frugal-phile(tm)
planet10's Avatar
We don't use the connecters, just solder to the main terminals. The connectors are for people who insist on using far too fat speaker wire. With the needs of an A6p 24g solid (as found in CAT5/6 cable is more than sufficient (and IMO has DDR advantages over thicker/stranded).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th December 2014, 02:36 AM   #7
Tom - I knew a guy who a couple of decades ago took hard-wiring to the extreme of eliminating all connectors, signal and otherwise, and soldered everything -yup, even replaced the RCAs on phono to pre to power
I never actually heard the system, so can't attest to the layers of smear/ fog/ curtains , blah blah, thus eliminated, but I'm sure he heard the difference
now on sabbatical
Old 17th December 2014, 02:13 PM   #8
Bob Brines's Avatar
I use the connectors when I am prototyping. Then I can swap out drivers in a couple of minutes. Usually, I wind up putting a small loop in the end of a piece of 24ga wire and tack solder directly to the driver.
Bob
Brines Acoustics Web Site
Audio Alto with MA drivers? djanci Markaudio 15 12th December 2012 10:50 PM
FAST subs under MA drivers silverhairbp Markaudio 113 25th February 2012 09:49 PM
Magnet attached grilles for MA drivers, good or bad idea Squeak Full Range 18 4th January 2012 08:08 PM
Mounting guide for MA drivers. djanci Markaudio 2 23rd August 2011 04:30 PM
Crown MA-12000i / MA-5000i / MA-9000i jack2040 Solid State 4 8th March 2011 02:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
