Help with a port length, A7.3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 20th November 2014, 05:01 PM   #1
lorienblack's Avatar
Unhappy Help with a port length, A7.3
I've knocked up some boxes for a pair of A7's, the dimensions were decided upon due to where they are going and available ply I have.
Internal dimensions h x w x d
410x165x280 = a little shy of 19L
Driver placed 70mm from top inner surface.
I had planned to use some online software to work out a vent or port size, tuning box to to around 50hz. I have some ports 35mm internal diameter.
Problem is, each software I load the info into gives me wildly different information about the port length
Is there a trusted software for this sort of thing? And/or some good rules of thumb about where to place the port?
Many thanks for any pointers.
SQ exists only in your head :P
Port Length help? johncee1945 Full Range 2 27th April 2013 11:19 AM
Slotted port length and aero port length. deebeez92 Subwoofers 3 26th March 2013 05:18 AM
port length jwhit67 Multi-Way 1 6th March 2008 01:29 PM
Help with port length please Bobhof Multi-Way 3 2nd May 2006 07:32 PM
port length busterno1 Multi-Way 5 27th October 2003 09:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
