req. suitable cabinet for Alpair 7p - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th November 2014, 05:22 AM   #1
Default req. suitable cabinet for Alpair 7p
Hello,
I have ordered a pair of Alpair 7p. But not able to get much info on its cabinet.
Could you please suggest a suitable cabinet for Alpair 7p to get best out of it, for stand alone use (ie. without any other speaker/sub-woofer support)? Will be using it with TV (movies, music) or a music player (music).
thanks and regards
S Sarath
Old 5th November 2014, 06:20 AM   #2
frugal-phile(tm)
planet10's Avatar
Not all that many people have actually got A7p in use, so most people will have guesses.
My 1st guess is Frugel-Horn Mk3. Chris is in the midst of doing up another set for our use for these (and CHN, FE103 Sol).
I almost have a set of A7PeN done and have been walking past both the very first set of FH3 and Maeshowe...
I will be going up a full set of miniOnken (including CGR).
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th November 2014, 03:10 PM   #3
The frugal horn was the first thing to come to mind. I do not believe (someone correct me if I'm wrong) there are plans for a pensil cabinet yet.
Space and budget permitting, a small powered subwoofer may be another option if power handling/SPL is a concern.
Cabot Acoustics
Old 5th November 2014, 04:12 PM   #4
Scottmoose's Avatar
Should do fine in FH3 (I've checked). Dimensions for 7P pensil now with Dave & Mark.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 5th November 2014, 04:27 PM   #5
Tabaq?
TABAQ TL for Tang Band
If you ask politely probably Bjohannesen will crunch the numbers for you.
It already has been done with 10.3
Old 5th November 2014, 05:14 PM   #6
chrisb is offline chrisb  Canada
For compact footprint, a Pensil should work as well. - Scott / Dave has that been modeled / drawn yet? - I've lost track.
now on sabbatical
Old 5th November 2014, 06:03 PM   #7
Originally Posted by Scottmoose View Post
Yes, sent the dimensions to Dave earlier.
yes, if I'd read the entire thread I'd have seen that - as much as I love the FH3/XL, there's something to be said for the ease of build and compact footprint of the Pensils - hard to fault either of the formats
if Dave is "going" up a full set of miniOnkens, how many does that mean I'll need to build?
now on sabbatical
Old 6th November 2014, 04:29 AM   #8
frugal-phile(tm)
planet10's Avatar
Has its own thread:
Pensils for Alpair7p, CHN-70
dave
Old 6th November 2014, 05:41 AM   #9
If floor space is not a concern, and with only performance is considered which of these will bring best out of Alpair 7p when used without any helper woofer/sub-woofer?
Old 6th November 2014, 06:34 AM   #10
frugal-phile(tm)
planet10's Avatar
Probably Maeshowe. FH3 if that is too big.
dave
ALPAIR 7P & ALPAIR 12PW combination. markaudio Markaudio 197 15th December 2014 11:25 PM
Alpair 7P developments markaudio Markaudio 28 18th November 2014 12:38 AM
Mark audio alpair 7p vs alpair 7.3 sarathssca Full Range 79 31st October 2014 02:14 PM
ALPAIR 7P - launch - specs markaudio Markaudio 35 27th August 2014 04:58 AM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 06:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
