Alpair 7.3s in panels? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 10th September 2014, 08:12 PM   #1
AndrewR is offline AndrewR  United Kingdom
Default Alpair 7.3s in panels?
Hi all,
I recently moved house and need to find some neighbour-friendly loudspeakers - where the music doesn't collapse at low volumes. My big Audio Note AZ-Three loudspeakers don't fit the bill and only work well in corners.
What I believe I need are some single driver panels and the following video of Alpair 5 drivers seems provide amazing performance:
????????????????? - YouTube
Sadly those Alpair 5 drivers are afaik no longer available. However the Alpair 7.3 Grey drivers seem to have a high Qts (0.54), good F0 and great XMAX. Question is, would the Alpair 7.3 really work well in a large open baffle design? Say about 100cm wide x 80cm high.
Amps are 300B SET, but not playing head-banging volumes. Their impedance looks SET-friendly.
Andrew
Andrew Randle
The Hi-Fi Watcher
Old 10th September 2014, 08:50 PM   #2
frugal-phile(tm)
planet10's Avatar
Like all small OBs you will need a bass helper to generate serious bass. But other than that it should work well.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th September 2014, 10:44 PM   #3
markaudio's Avatar
Originally Posted by AndrewR View Post
Hi all,
Andrew
Hello Andrew, Guys,
Alpair 5 not longer available - they will be in the future, see here:
CHS40 and CHS50 early developments
CHS40 and CHS50 are the direct descendants of the original driver. Most Alpair 5 went to Japan, hence videos of the type Andrew found. Japanese end-users are directly feeding their views and desires into the CHS development. There's a Japanese approach to continuous improvement often refered to as 'kaizen' that I follow. Now is the time to feedback to influence the design of these drivers on their development thread.
Mark.
3s tech driver card timwebb Car Audio 2 16th September 2013 07:31 PM
Genesis model 3s 8"woofer replacement??? crispycircuit Multi-Way 9 15th July 2013 01:26 AM
Repairing Acoustat 3s, or making 1+1s... Frommerstop Planars & Exotics 20 6th July 2012 09:49 PM
Advice on new/used player + manual for Nakamichi MB-3s TDWesty Digital Source 3 12th October 2005 03:12 AM
Mounting TO-3s Devil_H@ck Parts 7 30th March 2004 08:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
