ALPAI 12PW - Launch - specs - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 17th August 2014, 09:26 AM   #1
markaudio's Avatar
Default ALPAI 12PW - Launch - specs
Hi Guys,
Here's the information and specifications on the Alpair 12PW. I've had to vary my time on the factory floor these last few months for reasons most of you know. As a result, Evan Yu has done much of the last minute adjustments to this driver. He's done great job. Together with Matsubara san (Farther designer of the Fe series), this driver should provide those enthusiasts intent on making larger systems with allot of "big-box" potential.
The 12PW retains the Semi-Free-To-Air single suspension design. Quite a challenge to get the rear suspension to handle the load extension. I've set its limit via the arrestor @ 8.5mm (1 way). Experienced at serious (sensible) end-users should aim to max-out the excursion at around 50% of the available mechanical extension. In a 40litre to 50litre box, this driver will make some serious bass without having to break into a sweat. I spent allot of deign time on re-tuning the PW's power-train and motor sub-assembly to get it into this operational envelope. My main goal was to retain a low-mass power train tha would remain stable under the influence of a reduced damping load. The PW has a low moving mass of under 12grams. It will be easy to driver despite its reduced SPL from its Full-Range sister.
Please remember the 12PW remains a light-duty driver. Those into "head-banging", "continuous rock-un roll" or intent on ear drum damage, the 12PW is NOT the driver for you. If however, you want to go low and get a serious audiophile quality sound where you can easily tell the audible difference between a double-bass and a bass-guitar when both instruments are oscillating at <40 cycles, this IS the driver for you.
Please pay attention to the PDF's running in and power handling advisories. This driver needs care when running-in. Its rear suspension's elastic load tolerance requires the 100 hours of low volume load to gradually get all the cross-weave fibres evenly loaded. If you give the PW a some "heavy blasts" during the run-in, you'll risk over-stretching the inner sections of the spider.
Box combinations. Dr Scott L, did some basic calculations for box volumes, which come out in the 35 litre to 50 litre range. Box alignments and port/vent tuning frequencies should reach down to the low 30's Hz. Box designers, enjoy!
Cheers
Mark.
Old 17th August 2014, 10:20 AM   #2
Scottmoose's Avatar
Q & Vas are moderate, so the driver wants a larger volume than many similarly sized units. 45 litres tuned to 33Hz should do a nice job, with a lightly damped alignment.
Community site www.frugal-horn.com Commercial site www.wodendesign.com
Old 17th August 2014, 09:18 PM   #3
zman01 is online now zman01  Bangladesh
Potential for plenty of interesting designs/combinations with the A12PW... wishing you all the success with your 3 new products.
Take care.
- Zia
Old 19th August 2014, 12:06 AM   #4
nirvana is offline nirvana  Canada
nirvana's Avatar
the 7P is less efficient than the 12pw....
Old 19th August 2014, 12:18 AM   #5
frugal-phile(tm)
planet10's Avatar
Just like one wants. Woofer should be 3-6 dB more sensitive (when you XO at the BS)
4 in 100-120 litres looka good.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th August 2014, 12:19 AM   #6
Bob Brines's Avatar
Once you adjust for baffle step....
Bob
Brines Acoustics Web Site
Old 19th August 2014, 08:45 AM   #7
Scottmoose's Avatar
Is it? If you look at the FR responses you'll see they're actually about the same, hovering around the 90dB region.
The 7P is evidently designed to be a paper-cone version of the Alpair 7, i.e. it's a wideband driver capable of being run solo, not a dedicated cone tweeter. No doubt Mark could have kicked sensitivity up above 90dB, but to achieve that in a unit of this size you would almost certainly have to accept a significantly shorter VC to reduce powertrain mass, very limited suspension travel & a more powerful motor, all of which would result in a much lower Q & a higher F0, significantly limiting its wider use.
Old 19th August 2014, 12:35 PM   #8
Do you think we will see a variant of the paper cone colour?
The graphite/black MAOP Alpair ones in my opinion look darn sexy!
Old 19th August 2014, 05:08 PM   #9
chrisb is offline chrisb  Canada
MAOPs in dark finish? my MAOP7s are white
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 19th August 2014, 06:45 PM   #10
IIRC Mark posted some pics of graphite/black cone variants quite a while back... or is it just our imagination?
Found it:
Post #129 at Alpair 10 Gen. MAOP Prototype TW-1
ALPAIR 7P - launch - specs markaudio Markaudio 35 27th August 2014 03:58 AM
Product launch in the UK Waly The Lounge 13 17th February 2014 04:58 PM
Logo Launch sale! jtktam Audio Poutine 2 1st August 2013 05:51 AM
cDAC+ Launch Sale xCanadianPandax Audio Poutine 0 7th April 2013 11:07 PM
Shuttle Launch Audio - DIY? ImperfectSense Everything Else 4 6th October 2011 02:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
