Mount Markaudio drivers with glue - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 4th August 2014, 09:41 PM   #1
spekr is offline spekr  United States
Banned
Default Mount Markaudio drivers with glue
Any recommendations how to mount Markaudio drivers with glue only? What type of glue is recommended? What to avoid? Any glue that is removable? Any additional tips?
Thanks!
Old 4th August 2014, 09:48 PM   #2
vinylkid58's Avatar
Why would you want to glue the drivers in place?
jeff
Old 4th August 2014, 09:56 PM   #3
vacuphile's Avatar
Gluing drivers in place is something I do all the time. I use a polemerizing caulk that turns into a rubbery substance. Advantage is that drivers can still be removed, since the caulk remains flexible.
silicone or acrylic caulk should be avoided, what you want is so called ms polymer sealant.
Old 4th August 2014, 10:01 PM   #4
jemraid is offline jemraid  United Kingdom
Hello Spekr,
Well if you really must do it :-) Try a latex based carpet glue, if I was going to do it here in the UK I would some stuff called Copydex. To remove the drivers you would have to use a screwdriver to lever them up and away from the glue, You would be able to peel the glue from the rear of the units and off the cabinet especially if it was painted or varnished.
I've done the same in the past, poked a screwdriver through a driver cone, a bit of masking tape cures it but it doesn't look very good.
Cheers - Jim
FH3 build using very simple tools and a point to point Gain Clone with largish power supply. http://www.jasread.com/fh3/index.html
Old 4th August 2014, 10:03 PM   #5
doorman is offline doorman  Canada
doorman's Avatar
I don't understand why someone would use glue instead of the supplied fasteners to secure drivers. Simply removing the said fasteners makes for the easiest possible removal.
Old 4th August 2014, 10:08 PM   #6
vacuphile's Avatar
Screws are primitive because they need a large flange on the basket.
Old 4th August 2014, 10:13 PM   #7
vinylkid58's Avatar
You've obviously never seen a Mark Audio driver.
jeff
Old 4th August 2014, 10:22 PM   #8
Banned
Thanks!
Does the polemerizing caulk dampen the driver movement or might it even work as a spring (at certain frequencies)?
Why not use silicone or acrylic caulk?
Old 4th August 2014, 10:54 PM   #9
vacuphile's Avatar
Acrylic is not strong enough and silicone is a bijatch to work with, stinks and has unpredictable results.
There is not really any springy or dampening effect the way I use it. The layer is just to thin and the surface area to be compressed too large.
Old 5th August 2014, 01:27 AM   #10
frugal-phile(tm)
planet10's Avatar
Glue is a bad idea IMO.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Commercial uses of the Markaudio drivers Squeak Markaudio 1 4th March 2013 01:43 PM
Surface or flush mount Markaudio CHP-70 AUtgr85 Markaudio 2 26th September 2012 06:11 PM
Zigmahornet with Markaudio drivers? StevenZ Markaudio 13 26th May 2011 06:09 PM
5.1 system with Markaudio drivers? Rick J. B. Markaudio 17 4th January 2010 06:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
