Mount Markaudio drivers with glue - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th August 2014, 04:39 AM   #11
RXV is offline RXV  Philippines
Just use the stock screw holes and screw them as they should be.
If you're afraid if possibly puncturing the cone, then put a small piece of thick carton or dense sheet (vinyl) on top of the cone to cover it (while screwing) and prevent any accidents in case they would happen.
Most (if not all) MA drivers have rubber gaskets included so that no air leakage would occur, if that's what you're after
Old 5th August 2014, 04:41 AM   #12
And besides, by gluing your drivers, your screw holes would show up empty (holes) without the supplied hex screws. Not aesthetically pleasing IMO.
Old 5th August 2014, 07:30 AM   #13
spekr is offline spekr  United States
Banned
Originally Posted by planet10 View Post
Glue is a bad idea IMO.
dave
Why?
Old 5th August 2014, 03:00 PM   #14
Bill poster's Avatar
fill the holes in the surround cover and spray, or rebate slightly deeper and cut a surround cover
Old 5th August 2014, 06:02 PM   #15
chrisb is offline chrisb  Canada
Originally Posted by spekr View Post
Why?
Well for one thing, I think that production issues have required that Mark's drivers are no longer shipped with attached "super gaskets" and the webbing on rear side of injection molded resin frames would require rather lot of glue, which could get very messy.
While I find them longer than required when drivers are rebated, the supplied screws work very well, and as RXV noted, a piece of cardboard or such should provide the required prophylaxis
now on sabbatical
Old 5th August 2014, 09:22 PM   #16
Banned
Do you have a picture how the rear looks like now without the gasket?
Old 5th August 2014, 10:12 PM   #17
From a several year old dead A12M, but I don't think the frame casting has changed much - on this particular frame, those webs are 6mm deep - less on other models, but I've never needed to measure them before
now on sabbatical
Old 6th August 2014, 12:26 AM   #18
Re the question of damping the drivers, in combination with the (now) separate gaskets and resin composite frames (with exception of new CHN70) , the MA drivers are rather well damped to start with - but if you want to increment that, a layer of closed cell foam weather stripping on the enclosure baffle and under torquing the mounting screws should provide sufficient isolation, while maintaining acoustic seal.
now on sabbatical
Old 6th August 2014, 09:05 AM   #19
Banned
Thanks! Looks like the cavities would provide additional area so glueing the driver would work even better.
Old 6th August 2014, 09:41 AM   #20
Could you glue the magnet to some sort of bracing? And support it from behind instead?
Commercial uses of the Markaudio drivers Squeak Markaudio 1 4th March 2013 01:43 PM
Surface or flush mount Markaudio CHP-70 AUtgr85 Markaudio 2 26th September 2012 06:11 PM
Zigmahornet with Markaudio drivers? StevenZ Markaudio 13 26th May 2011 06:09 PM
5.1 system with Markaudio drivers? Rick J. B. Markaudio 17 4th January 2010 06:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
