CHR70 vs. A7 - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 25th June 2014, 08:59 PM   #41
doug01n is offline doug01n  Brazil
Well, you have asked about the golden ratio BR... I did one. Not an ideal construction, but it's very good for burning the speakers untill the FH3 is ready. My friend does laser cut on MDF, but only 6mm max. So I design it on skectch up and here's what's playing on my living room right now:
There's some braces on the marks, every wall is braced to reduce vibration, but of course is not the ideal.
This is the laser cut panels and braces:
The port is in square form, and made with same wood to keep asembling easy.
As you can see, the provisory stands are not the ideal too... lol
What can I say about this set? It simply beats ANY of the comercial small stereo speakers I had listened. I think the A7s are the finest speakers I ever heard, except for the bass part. The bass is a little boomy and doesn't go as low as I want (yet), lacking some punck on drums kick too. There's no impact, but all these problems are certainly caused by the 6mm walls of the cabinet, not the speaker itself.
Old 26th June 2014, 05:22 AM   #42
chrisb is offline chrisb  Canada
with all due respect, 6mm MDF and "braces" would seem to me to be oxymoronic - no matter how precisely cut or interlocked
try a well braced enclosure with 12mm BB or equivalent plywood to showcase what these "little" drivers can accomplish
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 26th June 2014, 08:39 AM   #43
Squeak is offline Squeak  Denmark
Squeak's Avatar
Laser cutting is a wonderful tool. Would probably be my first choice if given the choice between all the different maker tools available now. You just have to live with the limitation of cutting depth. But you can stack! Double up or preferably trible up on all the panels then you're going somewhere. You could even do a middle layer with a different kind of material like acrylic say, to get a very high quality dead sounding panels (sound doesn't "like" to travel between layers of different acoustic properties).
Edit: Looks like you actually doubled up on the front panel. But the driver isn't flush? It would seem the material has the perfect thickness (6 mm) to do that.
Old 26th June 2014, 10:03 AM   #44
Yes, the front wall is a double layer, with a different hole size for the speaker. It's a good thickness for it. There's no screws, just glued together.
I was thinking in 3 layers, with ply in the meadle, but it's not my objective to stay with this BR cabinet. It's just for burning in the drivers until I finish the FH3. I was thinking about the pensio, but I think I will like more the Fh3 in the lower end.
The driver is fixed trough the screws that come with it, but I can't get them too tight, or the screws would make a damage in the mdf, getting lose there.
Old 26th June 2014, 11:20 AM   #45
Squeak's Avatar
If you are planning to the veneere, paint or wallpaper the FH you might as well get that lasercut too. I bet the PDF drawings could even be modified slightly to allow those to be used. If the cutting area is too small you could probably split it up into smaller parts without any loss of strength, if you do proper overlapping.
Old 26th June 2014, 07:32 PM   #46
Chrisb, I totally agree with you. This is a temporary box, low cost objected. I just laser cut it because my friend made that almost for free. But even with this cabinet, the A7P are already showing what they can do. I'm already impressed, and will be more and more with a properly done FH3.
I think about laser cutting it too, but the laser cut of my friend doesn't cut in angles. Will have to try a different way of doing the angled parts. But for a Golden Ratio BR, it can be a lot easier.
NZ All Black CHR70's markaudio Markaudio 1 24th May 2013 03:41 AM
CHR70 ShoeBox-70.3 Spec Markaudio 53 15th March 2013 09:07 AM
K.I.S.S - CHR70 Project thunk303 Full Range 10 22nd June 2012 02:16 PM
A happy snap of my CHR70's ALTRE552 Full Range 18 22nd October 2011 06:41 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
