Omnidirectional Alpair? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 22nd May 2014, 08:19 AM   #1
Default Omnidirectional Alpair?
Hi all!
I've just got a quick question regarding box design for the A10P or A12P.
I've currently got a pair of Duevel Planets (Planets Entry Speaker) which are two way omnidirectional speakers with a downward-firing bass port and spherical diffusers on top. They aren't the last word in quality I'm sure, but they are fun, look great and have a large sweet spot.
I'm currently putting together a couple of low watt tube amp kits and thought it would be fun to also make a higher efficiency, single driver version of the Planets.
I have no experience in speaker building, so I was wondering whether I should just take the Pencil design, readjust the dimensions to make a square (rather than rectangular) prism shape (but keeping the same internal diameter), move the driver cut-out to the top and move the vent to the bottom, and then add feet and a DIY diffuser at the top?
I also expect that with the radial diffusion, it's likely the treble would be attenuated, so the A10P would likely be a better candidate than the A12P, despite the lower sensitivity.
Or should I commission a custom design from a notable member of this board, with the caveat that I understand that I would have to experiment with the diffuser part on my own.
Thanks for your time in reading this and your thoughts!
Taz.
Old 22nd May 2014, 08:28 AM   #2
frugal-phile(tm)
planet10's Avatar
Originally Posted by Mistertaz View Post
move the driver cut-out to the top.
Taz,
Movin the driver from its specified Zd (offset) will degrade performance, and it won't be a Pensil any longer.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd May 2014, 09:57 AM   #3
Originally Posted by planet10 View Post
Taz,
dave
Ahhh... Thanks for that info Dave. I think I'll contact someone for more advice.
Thanks!
Taz.
Old 22nd May 2014, 03:16 PM   #4
I'm not sure why people are so interested in wide dispersion drivers. I sit in one position, one chair, for listening. I don't get up and move around the room except to change a record (no music on anyway). I use a Herron VTSP-3A preamp which has a remote, so I don't need to move to change source or volume. My seating position and speaker position are optimized for best performance. I rarely have others over to listen.
So there is one listening position, I don't care if the speakers roll off significantly 15 degrees off axis as long as they sound good at the seating position, the sweet spot.
There is some benefit to not using wide dispersion speakers in that there is less side wall interaction in the upper mids and highs with narrow dispersion speakers. I learned this a long time ago with Acoustat Model 4 speakers. Very directional and low dispersion. One sweet spot. Low side wall interaction.
Old 22nd May 2014, 05:20 PM   #5
Scottmoose's Avatar
Possibly because other people may be present and wish to enjoy the music also.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 22nd May 2014, 05:39 PM   #6
Bob Brines's Avatar
Maybe. It seems that the overwhelming requirements for speakers are pinpoint imaging and pounding sort of bass at ~80Hz. Those who require the latter, at least in the sense of a single driver speaker need not be on this particular forum. It also seems that a large percentage of posters are confined to 10'x10' bedrooms or odd corners of a great room that is hugely asymmetric. The great destroyer of imaging is early reflections. forcing the speakers close to the sidewalls destroys imaging. An omnidirectional speaker will splash off of the sidewalls and also the front wall. Worst case for imaging. Dipoles will not, at least in theory, illuminate the side wall, but will reflect off of the front wall.
IMO the best positioning on the speakers is on the long wall where the side walls are no longer early reflections, or at least substantially reduced in power level, or at 45* across a corner were the side wall reflections will be primarily aimed behind the listener.
You want a large sweet spot? Toe the speakers out 10-15* and well away from the side walls.
Bob
Brines Acoustics Web Site
Old 22nd May 2014, 09:27 PM   #7
And that is the point I make. Well more than 99% of the time, I listen alone. And even with the Acoustats and Martin-Logans, very popular speakers, there is one sweet spot. Even with some wide dispersion speakers, there is one sweet spot because being off to one side or the other changes the balance, image and soundstage.
I suggest that when reproducing a well-recorded symphonic work, there is one sweet spot where everything locks in regardless of how wide a speaker's dispersion.
Old 22nd May 2014, 10:57 PM   #8
Scottmoose's Avatar
Understood, but it's also largely dependent on what the 'sweet spot' is, since impressions will inevitably vary with individual perception & taste. I would however suggest that since not everybody listens to music alone, driver manufacturers need to factor a reasonable power response / dispersion into the equation. Otherwise, if we took it the other way to the logical extreme, we'd all be either using headphones, or focussed arrays, which are more or less the ultimate in that sense, but weld you into a single location.
Old 23rd May 2014, 06:09 PM   #9
chrisb is offline chrisb  Canada
Focused arrays certainly do that, but I've always found headphones / earbuds do exactly the opposite - i.e. the acoustic soundstage follows whatever position your head is oriented - which is one of the things I find most unnatural about them.
Background chatter on Pink Floyd DSOTM is particularly disorienting in monaural - I already have enough voices in my head, thank you very much.
now on sabbatical
Old 23rd May 2014, 06:31 PM   #10
Scottmoose's Avatar
You hear voices Chris? You could make a fortune holding sťances.
Good point though re the perceived differences between the two. Obviously not one of my brighter moments last night...
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 04:37 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 06:04 AM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
