port installation - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 16th February 2014, 09:41 PM   #1
paul burchell's Avatar
Default port installation
The cut out for a 1 1/2" port is approx 1" larger due to the large splines or ribs on the neck, after looking at the dry fit i wonder is this a week link in trying to create a air tight box. The idea was to epoxy the edges of the ribs and the under side of the flange but this still leaves questions on how air tight this connection will be, i then thought about filling the space inside with acoustic sealant but that goop will get all over the stuffing during tuning. After building 3 homes i know how messy that stuff can be.
Any suggestion or in site into this thanks
Old 16th February 2014, 10:20 PM   #2
chrisb is offline chrisb  Canada
Duct Seal?
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 16th February 2014, 10:32 PM   #3
Thanks Chris
Old 19th February 2014, 04:07 PM   #4
cogitech's Avatar
I used outdoor acrylic caulking for that. Lasts forever, fills gaps, perfect seal, bonds well to both the wood and the plastic...
port spacing for dual port design Hezz Subwoofers 3 27th August 2012 04:42 PM
Port lengths for 2-chamber 2-port bandpass Circlotron Subwoofers 12 15th February 2011 12:09 AM
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
Single Port Vent Better than Dual Port? Daveis Multi-Way 18 15th July 2007 05:12 AM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
