Mc42's (Michel) 10P project - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 8th February 2014, 12:50 PM   #11
Scottmoose's Avatar
I'm not entirely convinced that pipe harmonics provide the same 'clean sound as open baffles.' Without dimensions for the cabinet, difficult to assess technical performance, but it will conform to the known laws of physics. Be that as it may though, providing it does what you want it to do & you like the results, that's what counts.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 8th February 2014, 04:28 PM   #12
markaudio's Avatar
Hi Michel, Guys,
I'm glad Michel has posted an internal pic of his enclosure. Please check the attached pic to this post. Note the red area behind and each side of the driver has no damping. Omitting damping in these areas is not good. There's a real risk of back-wave cancellation effecting the driver's performance. In Michel's design, the internal back and side walls are so close to the driver, its 99% certain they will create some reflection onto the rear of the driver's cone.
As said, I'm all for guys experimenting but its still important to design a box that doesn't significantly compromise the driver's function.
Mark.
Old 8th February 2014, 04:37 PM   #13
paul burchell's Avatar
Expansion foam insulation ??? interesting
Old 8th February 2014, 04:41 PM   #14
Bob Brines's Avatar
If so, it probably provides some panel damping, but being closed cell, does not provide any wave damping. It just takes up volume.
Bob
Brines Acoustics Web Site
Old 8th February 2014, 04:49 PM   #15
I would assume by the spongy or bubbly look of ex foam when you cut into it that it would be considered open cell but that is just my assumption
but i guess the surface area when cured is smooth and not porous
Old 8th February 2014, 05:58 PM   #16
4mc2 is offline 4mc2  Canada
Originally Posted by markaudio View Post
Hi Michel, Guys,
Mark.
Hi Mark , I can put some damping pad near back of driver for see if make a some differenc in sound .
I have tested the 10P in BR before and the sound from my design is more articulated .
He have only reflection near center axe that can return to back of driver but the all other reflexion ( 80% ) can not return ......... physic of wave
Anyway my ear love it ! ...... I am not the first ( some speaker compagnie from France ) that put the back wall very near the drive .
The compacted foam is for more rigid of wall
Old 8th February 2014, 09:02 PM   #17
I have put a small pad around back of drive .......... and the sound if he have difference ,it's very subtle !
I have make a patern of reflexion .......... only the red can have some problem
The best make your proper experience ........ it's the best scholl !
Old 25th July 2014, 11:44 PM   #18
markaudio's Avatar
Hi Mc,
I think other diyer's in the past have tried Alpair 12P on the basis that its closer to the Coral 8's size.
I recommend you try the Alpair 12P, better suited to the larger room size.
Mark
Old 26th July 2014, 12:05 AM   #19
Hi Mark
Perhaps later !
You know the magnetic power inside the air gap ( voice coil .) .... in Maxwells... for the 12 P and 10P ?
I like to buy your Beta 8 for a friend that search one .
p.s. you know where I can rebuid a old voice coil ( burn ) for a Flat 8 with a copper/aluminum wire like your Alpair have ?
Mike
Jean Michel on LeCleac'h horns angeloitacare Multi-Way 1785 26th September 2014 08:12 AM
hello , me Jean Michel jean michel Introductions 10 22nd November 2013 08:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
