Twin Alpair 7's studio monitor build. - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 1st March 2014, 03:51 AM   #31
frugal-phile(tm)
planet10's Avatar
F = 1/(2*pi*R*C)
Some iteration has impedance at 6.5 ohmm F = ~350 Hz.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st March 2014, 09:09 AM   #32
Scottmoose's Avatar
Spot on.
Community site www.frugal-horn.com
Old 1st March 2014, 09:46 AM   #33
frugal-phile(tm)
planet10's Avatar
Originally Posted by xrk971 View Post
When I modeled the dual A7.3 in a sealed cabinet wired in series with a 70uF cap across the lower driver, I get a response that falls off starting at 2 kHz.
Given the wiring of the drivers, FR should be the same as a single driver (voltage amp assummed) If not something is wrong with the sim.
dave
Old 2nd March 2014, 01:00 PM   #34
paul burchell's Avatar
Hi Scott
Robert and I have built a duel chamber test box or double bass reflex as he calls it to do some testing for a single A10 . I was wondering your thoughts on how this might perform compared to the double A7 . For now our test box is only ported in the secondary chamber and we haven’t cut out or installed any drivers yet.
Thanks Paul
Old 24th March 2014, 02:52 PM   #35
BYRTT is online now BYRTT  Denmark
Originally Posted by lorienblack View Post
..........I have requested that the tech man does some measurements for me, so I hope to be able to post some results soonish.........
......canceled ?
Old 24th March 2014, 04:11 PM   #36
lorienblack's Avatar
We are back to the drawing board actually. The HF gain of the A7's in this design make the monitor a rather unpredictable performer. With the right material it heavenly, mainly acoustic and voices, but step too far outside and it can become uncomfortably bright.
Phase 2 will employ a design more akin to a FAST build. I have an inkling we will wait to see what new drivers emerge from the MA camp.
Old 24th March 2014, 04:34 PM   #37
Okay without some more active devices the box and drivers didn't make the monitor job alone. Thanks lorienblack for quick answer.
STUDIO MONITOR/DESKTOP MONITOR KIT ultimateherts Swap Meet 1 26th June 2013 03:21 PM
Alpair 7 - Twin driver studio monitor plan markaudio Markaudio 70 10th June 2013 02:36 AM
Bi-amp 3-way studio monitor - my first build linuslinus Multi-Way 10 25th August 2012 09:29 AM
Alpair 12 - Studio Monitor Plan markaudio Markaudio 19 7th February 2011 12:17 PM
Alpair 7 twin design vs. JBL 4312C monitors aptquark Full Range 42 30th June 2010 01:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
