New Woofs for 2014 - Page 17 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 13th February 2014, 05:45 PM   #161
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by chrisb View Post
... would require sourcing or development of new frame designs.
use what is available
probably both easy and cheap these days
sometimes we know very little, and sometimes we know too much
Old 13th February 2014, 06:48 PM   #162
Scottmoose's Avatar
Agreed. And with sufficient advance warning, hopefully easier to achieve since the front surround / cone can be sized to suit a frame that is likely to remain available for the foreseeable future.
Community site www.frugal-horn.com
Old 13th February 2014, 06:48 PM   #163
chrisb is offline chrisb  Canada
that's what I meant by sourcing
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 13th February 2014, 06:50 PM   #164
Scottmoose's Avatar
Old 13th February 2014, 07:17 PM   #165
badman is offline badman  United States
badman's Avatar
How about a Markaudio Hartley? IOW, a very wideband smooth response range of big drivers. Currently the best option for something like that seems to be either the Audio Nirvana (I'd be thinking something more damped/more travel/less efficient). Qts of around 0.4, 7mm Xmax, 90-92dB efficiencies. Very similar to JBL 123A/2213
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 14th February 2014, 02:11 PM   #166
I thought all could be well chosen standard parts, and only need proper assembling
but poleplates would ofcourse need machining to fit
Old 14th February 2014, 02:23 PM   #167
Scottmoose's Avatar
Right -but Mark will presumably want to have at least some design input into the components, & he won't want to find 12 months down the line the frame (or whatever) is no longer available, mandating a considerable redesign of other parts to fit whatever else he could get to replace it.
Good CES 2014 coverage .... a.wayne The Lounge 2 8th January 2014 11:48 PM
Keeping comment clean - 2014 markaudio Markaudio 0 4th January 2014 01:21 AM
So many DAC projects - which to choose for 2014? andyjevans Digital Line Level 3 23rd December 2013 01:13 PM
Countdown to Winter Olympics 2014 jackinnj The Lounge 0 21st February 2013 01:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
