Is my Alpair 10.3 damaged? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 11th December 2013, 12:28 AM   #1
Default Is my Alpair 10.3 damaged?
Hi All,
Just finished glueing my small MLTL enclosures for the 10.3! While breaking them in (about 20 hrs now) noticed a crackling in the "right" driver. When I lightly press on the dust cap, there is a small crackle. The other driver is smooth as silk. Is one driver damaged or out of spec?
Thanks,
Old 11th December 2013, 12:44 AM   #2
frugal-phile(tm)
planet10's Avatar
It sounds like the driver is defective. It should be covered by waranty.
One has to be very careful pressing the cone, it is easy to push sideways, but if it is noisy with music then it has a problem.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th December 2013, 12:49 AM   #3
Thanks for the info Dave. I hesitated to physically touch the driver but the sound was disconcerting so I wanted to see if both drivers were the same. The physical build of the unit looks fantastic though.
Mike
Old 11th December 2013, 07:42 AM   #4
I've found this is precisely the sound made when the frame is deforming, usually from uneven tightening of the bolts holding the driver to the baffle.
Similarly if you have rebated the drivers with out enough clearance or you've used real wood and it has shifted torquing the frame then the same occurs.
Another way I've had this happen is if the rear driver brace (if you have one) isn't square giving the same effect as over tightening.
Try alternately backing off on the bolts while listening to see if you can quash it that way.
Old 11th December 2013, 04:31 PM   #5
Thanks for the tips. I took the driver out and laid it on the table. The frame is dead straight. There seems to be enough clearance. Inspected the cutout. Seems ok. Crackle still there..
Old 13th December 2013, 06:20 PM   #6
Swap the drivers between the two enclosures. If the cracking follows the driver, there's a problem with the driver. If the problem stays with the enclosure, then the enclosure is the problem.
Old 13th December 2013, 06:29 PM   #7
chrisb is offline chrisb  Canada
Have you contacted the seller re warranty replacement? I believe Mark is pretty good about standing behind his product's vendors.
edit; I believe what nattonrice was referring to was unbalanced / over torquing of mounting screws - have you tested the driver in question out of the box?
now on sabbatical
Old 13th December 2013, 06:40 PM   #8
frugal-phile(tm)
planet10's Avatar
See post 5. Out of the box still noisy.
dave
Old 13th December 2013, 09:26 PM   #9
markaudio's Avatar
Hi Mikalanlee,
As per Silver's advice, swop the drivers over. Use the same power source and feed. You need to make sure the source, amp and cabling aren't causing the problem.
Should the problem remain on this particular driver, please return it to the dealer who supplied this unit. Provided the driver is in good condition with no physical damage, it can be replaced.
Mark.
Old 13th December 2013, 10:39 PM   #10
Hi Mark and all
I will swap the drivers and make double sure it is not the enclosure amp or cables. Thanks for the tips and recommendations. I would prefer to not send it back so I hope its a problem with my setup. No problems with any other drivers the 12p and 7.3 that I have. They all sound good.
Cheers
Mike
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 12:48 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
