CHR 70 Contraption - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th November 2013, 05:45 AM   #21
Sir Byrd, The drivers fit well. It took a bit of trial and error to get it sorted and lots of wasted pieces of MDF, but it now seems I have worked it out.
Old 5th November 2013, 05:58 AM   #22
SirByrd is offline SirByrd  United States
SirByrd's Avatar
But you got it right with a 1/4" straight bit and the jasper jig? Strange, I couldn't get it to work.
Old 5th November 2013, 07:06 AM   #23
Round the corners,....
and create a front reflex.
The bits...
And then some internal pieces of wood as per the design.
What a mess!
And this is the power supply and Amp.
Old 5th November 2013, 07:13 AM   #24
SirByrd's Avatar
Looks at the first picture in post #23, I think you may need to go over your upper left radiused edge one more time, looks a bit wavy. Check for any obstructions like putty or glue, happens to me all of the time.
Old 5th November 2013, 07:13 AM   #25
At this stage I plumbed it all in temporarily and had a listen.
WOW! I was so impressed. I have been running in the speakers for a few days on some laid-back jazz on low volume in their original packaging.
The detail is phenomenal. Vocals and acoustic guitars sing out with clarity.
A wonderful sound image in front of me.
This is when I really started to wonder what I was doing. The speakers are not finished and they sound amazing. I wonder how they would sound with decent separation and positioning in a room.
As I backed across the room away from the speakers some of the clarity certainly went away. Anyway - lets finish it first.
Old 5th November 2013, 07:19 AM   #26
So some questions....
I presume I should finish off the design with the angled pieces of wood at the back of the box?
Do they have a name?
And how do I build them and put them in the box?
Old 5th November 2013, 07:25 AM   #27
And another question....
Do people have an opinion on whether I should put in a pre-amp (volume control)?
I expect the input to be a phone and I can use the volume control of the phone.
I have also tried input from a laptop.
Or is there a better way?
I have seen a DAC with a volume control built in that takes a USB cable from the phone. I suppose that would sound better than a 3.5mm plug!
I think the CHRontraption deserves a quality source.
Your opinions and advice please.
Old 5th November 2013, 07:27 AM   #28
Yeah - first time I have used the curved edges - it is wavy. Thanks
I will have another go at that.
Old 5th November 2013, 07:28 AM   #29
A close up of the wired up speaker.
I have sealed those gaps around the edges.
Old 5th November 2013, 07:35 AM   #30
SirByrd's Avatar
Just one more pass should do it!
CHP-70, CHR-70 package size & weight nightuser Markaudio 11 14th March 2012 09:45 PM
chr-70 vs. chp-70? Sonogasm Full Range 10 26th November 2011 06:02 PM
CHR-70, CHP-70, Alpair 7 Desktops - Japan markaudio Full Range 4 1st February 2010 02:42 AM
F.A.S.T. Project: Tangband W3-315 vs. MARK AUDIO CHR-70, CSS EL-70 or Alpair jockel77 Full Range 13 12th January 2010 12:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
