The best fiberfill for Pensils in the UK? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 12th October 2013, 06:08 AM   #1
lorienblack's Avatar
Default The best fiberfill for Pensils in the UK?
FWIW I have stumbled on a fiberfill, that has so remarkably improved the sound of my 10.3m's, I thought I'd pass it on.
eBay number - 261069251792
Old 12th October 2013, 10:14 AM   #2
Send a message via Skype™ to JonSnell Electronic
Lambs wool is also very good and totally recyclable.
Support for Flying Mole, Allen & Heath, Valve amps and older designs. www.jonsnell.co.uk
Old 12th October 2013, 10:29 AM   #3
This is as close to carded lambs wool as I have found, from a man made fiber. I can wholeheartedly recommend it. With other types I have tried, the SQ dies as you get close to the recommended weight, not so AT ALL with this stuff, across the spectrum from a cymbal ring to a bass run - all sounds superb.
Old 4th November 2013, 01:18 PM   #4
A quick cheat is to take the polyester filling from a pillow. It has [usually] both a flat slab of polyester and also loose wadding within.
Old 19th December 2013, 09:54 AM   #5
As of yesterday I am using sheep wool in my Superpensils ( 12P ).
Comparison to polyfill : No comparison!!! Oh dear me is wool the way to go. I am blown away.
I am actually quite puzzled as to how much of a difference it has made..
Old 19th December 2013, 10:04 AM   #6
I tried carded wool as well, no real difference to the carded fiberfill, but a world better than the clumpy stuff. Even texture seems to be the key, if I was building again I might trial fiberglass throughout.
Old 19th December 2013, 10:08 AM   #7
This is not carded wool, though! It's long haired wool and thus i can create a fully amorphous filling inside the cabinet!
Old 19th December 2013, 10:20 AM   #8
Do you have a link to somewhere I could buy some, or look at a sample?
Poop - do I have to try EVERYTHING?
Pensils for Alpair 10.3 & Alpair 10p planet10 Markaudio 95 5th January 2015 06:52 PM
1+ years with chr70 pensils whats next? gideon Full Range 16 19th December 2012 06:54 PM
Wall damping in pensils? markre Markaudio 1 3rd January 2012 08:08 AM
Modifying Markaudio Pensils mahleriana Full Range 16 10th March 2011 09:50 AM
UK: Cat5 TNT Triple T Twisted Loudspeaker cables: UK dublin78 Swap Meet 3 14th May 2010 10:45 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
