Alpair 10P vs A12P - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 27th September 2013, 05:34 PM   #21
chrisb is offline chrisb  Canada
Kinku, keep in mind that while the two enclosures involved share the same design DNA, (Scott / Dave) they're not the same topology - FHXLs ( rear mouth tapped hypex horn isn't it?) for the 10P, and SuperPensils ) MLTL) for the 12s. I'd certainly expect that to add different spice notes to the sound stage / depth, but how much it might influence the area of your interest would be "informed conjecture"
so in other words, how we're each able to describe what we think we hear might not answer your questions
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 27th September 2013, 05:43 PM   #22
vinylkid58's Avatar
Originally Posted by chrisb View Post
how's this weekend sound? - might have to be Sunday though, our dance card's rather full for tomorrow, I think
I think Sunday will work. Apparently, the wife's got a function to attend, so the house will be quiet.
jeff
Old 27th September 2013, 06:11 PM   #23
jeff
except for the dogs
Old 27th September 2013, 07:12 PM   #24
vinylkid58's Avatar
They're just happy to see you.
jeff
Old 28th September 2013, 02:32 AM   #25
Bob Brines's Avatar
Sitting here half-way though three fingers of GLenFiddich, let me take one more shot:
Describe the difference between a lute and a guitar. Which sounds better?
Describe the difference between a metal-strung violin and a gut-strung violin. Which sounds better? Add a viola d'more to the mix.
Bob
Old 28th September 2013, 10:24 AM   #26
kinku is offline kinku  United States
Bob sorry,I got your point now. Thank you for this wonderful explanation. Jeff and Chris I will await your posts after this weekend experiments.Thank you so much. I am sure may are awaiting your results. Like all of you are trying to tell me,it may not be the actual results I am waiting for .But at least you can play the same music through both speakers , at same room and come up with some tonal qualities perhaps.
Old 28th September 2013, 12:20 PM   #27
markaudio's Avatar
Hi Chaps,
Bob's points do much to illustrate the design and build challenge each driver-designer faces. There will never be a "one driver pleases all" unit, its physically impossible to do so.
However, there are new design concepts that I'll be discussing this weekend while in British Columbia that might lend more future end user choice:
Mark's Canada/USA Sept travel dates
Cheers
Mark.
Old 28th September 2013, 01:00 PM   #28
Hi Mark , nice to hear from you. I was wondering what was your expectations when you were developing A10 and A12, or let me say advantage of A12 over A10. I am asking about the ideal situation where drivers are in free space and not in a 2pie space, as in a box of any type. I never read anywhere a comparison of raw drivers the strength and weaknesses of one over the other without any enclosures. May be you can help since you are the authority on them.
Old 30th September 2013, 07:45 AM   #29
well that chrisb guy sure painted himself into a corner, so let's see how artfully he can escape
After a delightful, but far too short visit with Mr Alpair himself yesterday, in which this subject was broached, I spent the best part of today listening to several combinations of Alpair systems and amps, both at my own place, and Jeff's.
Just to make things simpler, there were a total of 5 pairs of drivers in 3 different enclosures, as well as 3 different amps and 4 sources involved - lots of combinations
speakers:
my place:
- MAOP7s in FH3
- Alpair 10P stock in FHXL
Jeff's:
- Alpair 10P EnABLed in FHXL
- Alpair 12P stock in SuperPensil
- Alpair 12P EnABLed in MarKen12T
amps:
my place
- DIY 6CA7 SE triode wired (Shuguang Black Treasures)
- Tubelab EL84 P/P pentode wired
Jeff:
- Jolida 302 - triode wired ( Russian something or other outputs)
Sources:
my place:
- Jolida CD player / Citypulse DAC
- Rega P3 / AudioNote MM cartridge / DIY tube phono
Jeffs:
- DVD player (Jeff - brand = ?)
- turntable (even more embarrassed that I can't remember)
Conclusions?
I can't imagine being satisfied long term with the 12Ps in anything smaller than a Pensil or similar full size MLTL, or the big-a$$ Avebury rear mouth horns. Sorry, Dave - I love the A7s and EL70s in that style.
The MAOPs are a difficult driver to describe - I guess neutral is part of it, but they are very unforgiving of program material quality and associated equipment. The higher powered pentode amp was hard hard to endure - while the more forward dynamic placement of front of soundstage is easy to adapt to, they had a hard strident leading edge and dryness that was quickly fatiguing. The SE amp was much more relaxing and musically "right".
The soundstage presentation of the FHXL and Pensils are so different that it wasn't really an apples to apples comparison - either size of the rear mouthed FH enclosures throw a much wider, spacious stage behind the "back wall" than do the Pensils, and certainly the little stand mounted MarKenTs.
I jumped on board the EnABL bandwagon quite early, and am still enjoying the ride, if not the occasional flare-up of polemics. Suffice it to say that I preferred the treated to stock drivers in the FHXL by a substantial margin.
There's some very clear audience sounds and low in the mix musician's chatter and too close the mike compression in Patricia Barber's "Companion", that I've never heard quite so distinctly in the hundreds of times I've listened to the disc. They're just not there with the same dimensionality or "dark space" surrounding them with either size of the stock drivers. Yeah, I know that's pretty flaky audiophile mumbo jumbo, but it's what I heard.
As for a conclusive "verdict" on 10P vs 12P - that's just not possible for me at this time - Jeff will probably swap the treated 12s drivers into the Pensils, then it'll be a more valid comparison - well except for the enclosures....
If I had the time and financial wherewithal to build at least one of every possibly comparable design for all the drivers I'd like to taste, I'm still not sure I'd be able to find "the perfect one" - same for amps too, really
well, still stuck in the corner, but just let the paint dry a little longer and at least I won't track much mess around (sure glad I took a pee break first)
Old 30th September 2013, 10:15 AM   #30
zman01 is offline zman01  Bangladesh
Chrisb,
Again, top marks on your Houdini act...
Though I have not listened to the A10P, I can relate to the deeper soundstage of the FH design; few weeks back I had my FH3 playing with Mark's Gen 1 CHP-70 - the soundstage was indeed deeper (to my ears) and a bit wider vs other designs I have my FR drivers in (including larger ones). This lead to the feeling of a more "layered" sound and an enjoyable listening experience overall. I feel much inclined towards trying out the FH XL, but the 504mm depth of the cabinet is a concern... plus would need to buy a set of A10P and get them through the break in process...
Let's see what Jeff has to share.
Alpair 10P: Preview markaudio Markaudio 272 23rd April 2014 03:22 PM
Pensils for Alpair 10.3 & Alpair 10p planet10 Markaudio 66 31st January 2014 05:52 AM
Need advice for Alpair 10p build a3cervo Markaudio 40 21st December 2013 03:04 AM
A12P F.A.S.T Toppsy Markaudio 27 9th December 2013 06:21 PM
Ar 10p ??? jovan Multi-Way 0 6th January 2005 07:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
