need quick help with A10.3 info ! - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 15th September 2013, 08:57 PM   #11
Bigun is offline Bigun  Canada
Bigun's Avatar
I had a bash at some routing. It's been a year since I built the Big'un speaker and as a result it took hours to locate the relevant tools
Still, I managed to find it all. First image you see the set-up, with a drill bit sticking out as the centre-pin which pokes through a strategically placed hole in the scrap wood screwed to the base of my router to ensure the right diameter circle. I erred on the generous size for the outer circle to get a diameter of order 168mm and a rebate depth of a hair over 12mm. The inner circle, the cut-out, is something of worry because if you make this generous there's a risk of not leaving enough land for the mounting screws. The Alpair drivers have very little tolerance in this regard. I opted to under-size slightly at around 134mm diameter. I'll then manually enlarge the cut-out to suit the plastic frame supports. My router doesn't go through the total baffle thickness so I had to turn the pieces over and route from the back to complete the cut-out. To get the front and back cut-outs to line up you need to drill a perpendicular hole in the centre for the centre-pin. I managed to do a good job of this on one baffle, but the other was out (I really do need a drill press).
And the chamfers at the backside are done too.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 16th September 2013, 05:24 PM   #12
chrisb is offline chrisb  Canada
fun, huh?
now on sabbatical
Old 17th September 2013, 01:28 AM   #13
Bob Brines's Avatar
Has anybody figured out how to do the scallops without setting fire to the baffle?
I do like the two-stage chamfer. I might try that.
Bob
Old 17th September 2013, 01:43 AM   #14
Bigun's Avatar
It's a sign of serious DIY
It wasn't the intent when I started
Old 17th September 2013, 04:34 PM   #15
CNC router and very careful alignment ?
when I care enough about it, I'll just tidy up with some 80G PSA sandpaper wrapped on a scrap of 1 1/4" closet rod
Bob
I think that was accidental?
now on sabbatical
Old 18th September 2013, 12:39 AM   #16
paul burchell's Avatar
Bob
Frankly i prefer a gouge, rasp and a few lines
Old 18th September 2013, 02:38 AM   #17
Bob Brines's Avatar
Do you do a few lines before or after you work on your speakers?
Bob
Old 18th September 2013, 09:58 AM   #18
Bob
Sorry i ment to say a gouge,rasp then a few line
Old 18th September 2013, 01:40 PM   #19
Bigun's Avatar
I usually deliver a few lines with a bit of a rasp
Old 21st September 2013, 03:34 PM   #20
Bigun's Avatar
Some progress has been made on the porta-bench in my driveway
A couple of holey braces were positioned starting just below the driver cut-out where I want to stiffen things the most. Both braces are vertical, one front-to-back and the other side-to-side.
I then installed a number of other criss-cross braces from left over 2" wide 'sticks'. In particular I wanted to brace the port opening against the back of the box since the open edge is not supported otherwise.
I installed some thick felt lining around the inside of the top part of the box to tame high frequency reflections.
The driver has been dry-fitted to test the opening dimensions.
I'm probably about half way through the work effort now. It needs A LOT of tidying up before it looks presentable.
Dynaco A10 Robcrx Multi-Way 9 13th April 2012 03:51 AM
Duson A10 - help needed diabolis Solid State 4 28th March 2008 08:40 AM
Schematics for Eltax A10 Sub juz400 Subwoofers 0 11th February 2008 01:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
