My poor 7s - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 24th August 2013, 02:09 PM   #1
Default My poor 7s
A few months back I accidentally gave the cone of one of my Alpairs a bit of a bump during installation. The cone ended up with a bit of a crease and a slight indent but seemed to be purely cosmetic.
I've been noticing lately a fairly loud buzz coming from that speaker at specific frequency and low and behold the cone is starting to split along one of the creases!
Is it safe to say this driver is pooped? I was debating putting a dab of nail polish on the back side of the cone over the split to slow it down and or stop it from buzzing. Perhaps I should just toss it in trash.
It's a sad day
Old 24th August 2013, 02:49 PM   #2
Mooly's Avatar
I suspect something more flexible might be better long term. PVA type glue or impact adhesive (rubbery and flexible) applied to the rear of the cone. Whether it will cure the buzzing though...
Installing and using LTspice. From beginner to advanced.
Old 24th August 2013, 05:47 PM   #3
Lerg is offline Lerg  Canada
I would imagine that any adhesive applied to the cone will throw off the weight and balance of the cone since they are extremely light weight.
I would suspect that it is dead.
Old 24th August 2013, 06:19 PM   #4
chrisb is offline chrisb  Canada
See if you can contact Mark directly - repairs may be possible, but premature application of inappropriate materials or process can almost guarantee failure.
Lerg is certainly right the weight of these cones - if repairs are possible, I'd think you'd want to carefully apply balancing amounts of material in a consistent pattern - on both cones.
Say, I know a guy who sometimes paints cones....
now on sabbatical
Last edited by chrisb; 24th August 2013 at 06:23 PM. Reason: keytsroke errosr ( aka "Davish")
Old 24th August 2013, 08:39 PM   #5
frugal-phile(tm)
planet10's Avatar
I have certainly "binned" cones with less damage. The latest an Alpair10.2 i dropped the Allen Key on.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th August 2013, 11:39 PM   #6
I going to take a gander and say that this driver, while usable at moderate volumes now will be headed to the trash bin in the not distant future.
I suppose the next question is, save for the arrestor, is the Alp 7a different mechanically or electrically? If I purchased a 7a to replace this bummed 7, provided proper burn-in is provided, should these mate up well? Or am I looking at a new pair 7a's?
Thanks for the input folks!
Old 26th August 2013, 09:45 AM   #7
Scottmoose's Avatar
Same as the original 7.3 other than the arrestor to the best of my knowledge.
Old 26th August 2013, 05:54 PM   #8
IINM, the arrestor is not part of the active drive train, so there should be no measurable / noticeable difference until overdriven?
now on sabbatical
Old 26th August 2013, 07:01 PM   #9
Scottmoose's Avatar
Right.
Mark Audio Alpair 7s with full Planet10 modifications Scottmoose Swap Meet 6 23rd August 2011 03:01 PM
Is this a poor result? jamikl Multi-Way 2 18th August 2010 03:56 AM
Odd Woofers in these Mini 7s Scioneer Multi-Way 11 13th September 2007 12:05 AM
Recapped the Imperial 7s tonight geaugafletcher Multi-Way 2 26th April 2006 05:26 PM
poor switching classd4sure Class D 54 29th June 2004 12:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
