Torx Head Screws - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 22nd July 2013, 01:49 AM   #1
Bob Brines's Avatar
Default Torx Head Screws
As I went to install my new A10P's, I reached for the 1/8" Allen wrench that I have used in the past to tighten the screws and lo! The screw heads are now Torx T15. Not a big deal, as I have a set of Torx screwdrivers. Any reason for changing the screw heads? Inquisitive people what to know.
Bob
Old 22nd July 2013, 02:12 AM   #2
Speakerholic
Cal Weldon's Avatar
Allen?
Torx?
Robertson
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 22nd July 2013, 02:14 AM   #3
DUG is offline DUG  Canada
What Cal said!
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 22nd July 2013, 02:21 AM   #4
Bob Brines's Avatar
No, No! The screws supplied with the drivers. Trust me, they are T15. I use Robertson head drywall screws for just about everything, but I think that #6x1" drywall screws look a bit tacky for driver mounting.
Bob
Old 22nd July 2013, 02:26 AM   #5
Speakerholic
Cal Weldon's Avatar
Bob,
We understand that. I thought they were a reminder that you needed screws to mount the driver and the head size and colour should be similar to what was in the box. The length and width were up to you.
Old 22nd July 2013, 02:35 AM   #6
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
The story goes, the Torx was developed by GM & was used to secure head-lamp assemblies making it 'impossible' for consumers to readily change out headlamps by themselves. ..........or so the story goes. Witness the "new" three-bladed screws and the "one-way" screws........so the handyman in all of us can't open it up to do the "un-authorized" servicing.
__________________________________________________ __Rick...........
Old 22nd July 2013, 02:44 AM   #7
Speakerholic
Cal Weldon's Avatar
Every screw head has its place. Every one has its + and - . In the Tour de France of screws, Robertson takes the yellow jersey. We can argue if you like...
Old 22nd July 2013, 02:46 AM   #8
Bob Brines's Avatar
That and the fact that a Torx driver will not cam out of the head under heavy torque. Of course neither will a Robertson. Henry Ford (that Henry Ford wanted to use Robertson screws on his assembly line, but a patent battle pretty much kept Robertson screws out of the U.S. until rather recently. A couple of years ago, I went on a quest for a R2 screw driver. Never found one. But R2 bits with a 1/4" hex on the other end are available by the handful for power drivers.
Anyway, I do have a T15 screwdriver.
Bob
Old 22nd July 2013, 03:08 AM   #9
Speakerholic
Cal Weldon's Avatar
yep Phillips was the answer to the cam out problem with the robby's in the early days
Air pressure regulated and electric clutch systems made the Robertson better but Phillips was American and too well established to consider alternatives.
Torx? not sure, I haven't read up on that. Tremendous surface contact but serious limitations if you are stuck in the woods with a swiss army knife.
Old 22nd July 2013, 04:16 AM   #10
Robertson tips are the best at sticking in the fastener. They are for squares, and have been superseded. JMO, YMMV.
Socket Head Screws for Heatsinks? luvdunhill Parts 14 24th December 2007 05:37 PM
Need to source TORX toslink receiver pixpop Digital Source 11 25th January 2006 02:13 AM
Remote TORX problems... MWP Digital Source 3 24th February 2005 08:46 PM
Allen Head Screws & T-Nuts in Canada fireman Multi-Way 4 20th April 2004 01:30 AM
Torx 176 Bas Horneman Parts 13 15th October 2003 01:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
