Torx Head Screws - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 22nd July 2013, 04:30 AM   #11
Originally Posted by Cal Weldon View Post
yep Phillips was the answer to the cam out problem with the robby's in the early days
Air pressure regulated and electric clutch systems made the Robertson better but Phillips was American and too well established to consider alternatives.
Torx? not sure, I haven't read up on that. Tremendous surface contact but serious limitations if you are stuck in the woods with a swiss army knife.
Er, are you saying that Robertson heads were problematic because they wouldn't allow the fasteners to cam out properly?
Old 22nd July 2013, 04:37 PM   #12
chrisb is offline chrisb  Canada
Now we're debating who and why of best screw head design? What's next tapered shank vs straight, dual pitch thread (a la Confirmat assembly fasteners) ?
Don't we have better things to discuss?
So we either buy a Torx head driver to use the supplied screws - would probably cost less than a small Starbuck's coffee - or we use something else.
next?
now on sabbatical
Old 22nd July 2013, 06:58 PM   #13
next?
sorry about the pissy attitude, I guess I should finish my first caffeine before posting
now on sabbatical
Old 22nd July 2013, 07:41 PM   #14
mp9 is offline mp9  United States
...or not, i completely agreed with your post #12
Old 22nd July 2013, 07:47 PM   #15
vinylkid58's Avatar
It's ok Chris, you're allowed at least one rant, being that it's Monday.
Maybe Mark had a few too many complaints regarding the hex style screw heads, and decided changing the screw driver style to Torx might result in fewer mishaps when installing the drivers.
jeff
Old 22nd July 2013, 08:45 PM   #16
Speakerholic
Cal Weldon's Avatar
Correct, hence the invention of the Phillips. Remember, that was in the days before clutches and the powered drivers often led to wrist and arm injuries so they needed some type of release mechanism and it came in the form of the screwhead.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 22nd July 2013, 08:48 PM   #17
Speakerholic
Cal Weldon's Avatar
Probably, but you know my penchant for trivia and history so, uh, I guess no, I don't have anything better to discuss.
Next?
Old 22nd July 2013, 08:54 PM   #18
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
gosh...can't believe I once hated Torx screws
these days nothing goes without Torx...any other screw type sucks
Old 22nd July 2013, 09:05 PM   #19
Speakerholic
Cal Weldon's Avatar
Unless you have Robertson of course. Also a #2Robby just happens to fit a #3Phillips in a pinch.
Old 22nd July 2013, 09:10 PM   #20
a box with different types of 'bits' is easily available these days
just use the screw head to find the right bit
a pick out the best fitting
it's easy
btw, screwdrivers are no good anymore...only bits work
and this goes for any type of screw
but for unbraco/allen screws especially
Socket Head Screws for Heatsinks? luvdunhill Parts 14 24th December 2007 05:37 PM
Need to source TORX toslink receiver pixpop Digital Source 11 25th January 2006 02:13 AM
Remote TORX problems... MWP Digital Source 3 24th February 2005 08:46 PM
Allen Head Screws & T-Nuts in Canada fireman Multi-Way 4 20th April 2004 01:30 AM
Torx 176 Bas Horneman Parts 13 15th October 2003 01:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
