Bonded Logic Inc UltraSonic 12 Lining (A12P Pencil's and Moosebox) - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 28th June 2013, 09:30 PM   #1
mp9 is offline mp9  United States
Question Bonded Logic Inc UltraSonic 12 Lining (A12P Pencil's and Moosebox)
- would it be worth trying Bonded Logic Inc UltraSonic 12 in. x 12 in. Acoustic Panels?Bonded Logic Inc UltraSonic 12 in. x 12 in. Acoustic Panels (Package of 6)-60600-11212 at The Home Depot
Also wondering the general consensus on how many and much of the inner walls of the Standard A12P Pencil and Moosebox cabinets should be lined with the 1"x12"x12" panels?
And i'm not sure but i thought i read somewhere that Scott L. doesn't recommend any lining of the A12P standard Pencil cabinet, just stuffing, and vice versa for his "Moosebox" design, some clarification on that would be much appreciated.
Old 28th June 2013, 09:47 PM   #2
chrisb is offline chrisb  Canada
Looks to be very similar (other than the fabric backing) to the Ultra-touch 1/2" rolled produce we've used for several years now - and which appears to be NLA?
Scott would no doubt have particular reasons for his recommendations re lining or not of his various enclosure designs - I'd be inclined not to second guess on that subject.
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 29th June 2013, 01:32 AM   #3
Chris, the closest to that would be the .375" thick/radiant barrier http://http://www.homedepot.com/p/t/...N#.Uc43bhZGxlI
...i have no idea how different it is from the other products. The 16 in. x 48 in. UltraTouch Denim Insulation Multi-Purpose Roll-60301-16482 at The Home Depot is the best buy but it's 2" thick! Again i'd guess it may be the same material as the .375" thick Radiant Barrier minus the barrier outer layer, i don't know?
I'd hate to think the much higher cost of the 12"x12" acoustic panels are all marketing, that would be seriously messed!
Old 29th June 2013, 07:26 AM   #4
Scottmoose's Avatar
You can try if you wish of course, but the pensils, being transmission lines, are specifically intended to be stuffed rather than lined, which can't provide the necessary amount of damping by itself.
Old 29th June 2013, 07:55 AM   #5
Ok stuffing for the pencils makes sense that it's a transmission line. Specifically Wrt the Prncil's, i'm uncertain if it's a one or the other...or both line some or all walls then add the stuffing?
Old 29th June 2013, 01:15 PM   #6
Scottmoose's Avatar
Old 29th June 2013, 03:20 PM   #7
ok then
Pencil 12.2P Pencill Plans silverhairbp Markaudio 2 2nd June 2013 03:34 AM
74HC logic or No logic feedingthe Interface Receiver. Mario_JR Digital Source 2 10th July 2011 08:18 PM
Separating bonded glass mmerig Everything Else 14 19th March 2008 01:27 PM
74AC logic V.S. 74HC logic ? fastcat95 Digital Source 0 16th December 2006 03:03 PM
Bonded Fin Heatsinks jteef Pass Labs 1 12th March 2002 05:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
