frequency modulation of the upper ranges by the bass!! - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 13th July 2013, 11:03 AM   #41
Call me odd, but when I compared my Scan-speak 2-way with SDX7 acting as a sub-woofer(Both vented), and compared it to my Alpair 7's in their transmission line enclosure in my room, I prefered the alpair 7's. Even in heavy rock and dubstep. Would mention that i am using these in a 12ft x 9ft room though. (somewhere between 65-80dB is my usual listening levels)
In relation to the cones not being rigid, and having some form of flex, is there a system out there that can track the movement of the cone in a 3d field? Kind of like the laser testing i have seen but for the entire cone so you could end up with a slow motion, 3d capture of the cone when put under different loads?
Just curious, and a interesting thread!
Old 13th July 2013, 12:27 PM   #42
Scottmoose's Avatar
Yes, but they're custom designed & built AFAIK (same for the software controlling them), so you'd need to do the same. IIRC, MA use something like this, as do companies like Seas etc.
Upper frequency of Bass Drivers? Kev06 Multi-Way 28 17th June 2013 02:06 PM
Frequency modulation for PM5192 guitvinny Equipment & Tools 0 3rd November 2009 12:52 AM
lowest frequency ranges of LOTR RETURN OF THE KING SOUND TRACK? crippledchicken Subwoofers 10 27th July 2007 05:53 AM
Frequency Ranges & Effects? Xyberz Multi-Way 2 30th August 2002 06:33 PM
power as a function of frequency, and upper x-over point hakalugi Multi-Way 1 3rd December 2001 05:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
