Alpair 10P: Preview - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 28th April 2013, 10:22 PM   #21
dekiller's Avatar
If the 10P can fit the Pencil 10.2 design, my scratched Alpair 10.2 can send back for repair.
Old 29th April 2013, 02:00 AM   #22
markaudio's Avatar
Hi D, (Guys),
The 10P is a different driver to the metal 10, so existing Pensil box alignments won't match. You might still get a reasonable sound but not optimised.
Re "send back for repair", who's going to to this work for you? I've helped out a few members in the past but I've some way to go before I can do full time at the factory, so can't offer repairs. More important, the time needed to pick apart a driver, replace the damaged parts and re-align its power-train, ship it back and forth rarely is cost effective.
Mark.
Old 29th April 2013, 02:05 AM   #23
markaudio's Avatar
Guys,
I'm planning to be at the factory this Wednesday to complete testing of early production batches of drivers. I'll be posting the final data later this week to early next.
Mark.
Old 29th April 2013, 08:55 AM   #24
dekiller's Avatar
Hi Mark,
How about the 10.3? I want to purchase a new 2A3C SE , so , thats why I asking about the 10p.
Old 29th April 2013, 10:17 AM   #25
Scottmoose's Avatar
As Mark said, they'll probably go in, but don't expect them to be optimal; you'll be better off with the cabinet designed for them. Please be patient: I'll have a pensil for the new units worked up, but they won't be released until the EM specifications for the production units are confirmed. There's little purpose to trying to force the divulging of initial specs. and designing something based on those only to find a week later that some final changes to the production drivers have altered these sufficiently to require the box to be redesigned.
Old 29th April 2013, 01:35 PM   #26
dekiller's Avatar
Thanks a lot. If possible, workout a solution to modify Pencil 10.2 to suit Alpair 10.3 is desireable.
Old 29th April 2013, 02:33 PM   #27
Scottmoose's Avatar
I'm designing a new box for the 10.3 and 10P. When time permits, I'll look at the old one & see how the new drivers will behave in it; please remember though that I am not a magician, and there's only a limited amount I can do one way or the other.
Old 29th April 2013, 03:33 PM   #28
dekiller's Avatar
Thanks for your reply.
If the new drivers permits a reduce of internal volume, modification would be possible. Moreover, it is environment friendly.
Brian
Old 29th April 2013, 11:04 PM   #29
markaudio's Avatar
Hi Mark,
Hi Brian,
Either driver on a nice 2A3 amp should work well. Ummmmmmph......depends on your set-up requirements (room size, box type, musical tastes etc). Tell us more about your requirements.
Cheers
Mark.
Old 30th April 2013, 06:47 PM   #30
dekiller's Avatar
Originally Posted by markaudio View Post
Hi Brian,
Cheers
Mark.
Hi Mark,
Since I am listening to music at low volume every night till dawn, SQ is preferred to power 99% of time. A higher efficiency is good news for low-powered SET like 2A3. Actually, does paper cone handles high dynamics like metal cone? Moreover, which do think is better for Alpair 10.2/3, 2A3C SE or EL34 PP?
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 07:21 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 03:37 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 05:04 AM
Ar 10p ??? jovan Multi-Way 0 6th January 2005 07:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
