Alpair 10P: Preview - Page 13 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th August 2013, 09:16 AM   #121
frugal-phile(tm)
planet10's Avatar
Originally Posted by karloff70 View Post
lit looks like the 10P basically reaches lower than the bigger 12P full stop.
It does.
To further confuse you, i suspect that EL70 (4") goes lower than A10.3 or A10p. But not the 10.2.
The driver size is not a direct factor. There is a tendency forlarger drivers to have a larger Vas but this is not hard & fast (loose & goosey would be a bette metric). Qt & Fs are the other 2 parameters for figuring out theorectical sealed response.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th August 2013, 09:35 AM   #122
Originally Posted by planet10 View Post
It does.
dave
Thank you very much for pulling my head out of the wrong place. Seems the 10P is perhaps what I am after then.
Old 2nd December 2013, 12:33 PM   #123
Philosophil's Avatar
dave
Old 2nd December 2013, 12:35 PM   #124
Could someone help interpret the above graph for me? I assume it means that the bass drops off at around 100hz, but is there anything else that is significant here?
Old 2nd December 2013, 02:43 PM   #125
Octavia is offline Octavia  United States
I presume the sealed box with the bump up around 150 might make a sort of BBC monitor alignment.
Old 2nd December 2013, 03:42 PM   #126
Scottmoose's Avatar
Depends what you call 'significant'
Re BBC, almost. That one looks to have a Q of 1; IIRC, the LS3/5a had a Q of 1.1-1.2 depending on how many leaks there were in the box.
Community sites www.frugal-horn.com http://frugal-phile.com/
Old 2nd December 2013, 06:26 PM   #127
Since the graphs were posted without further comment as a response to a question about how the 10p and 12p might perform in sealed cabinets, I assume the graphs were supposed to speak for themselves. Unfortunately, while they may be speaking to others they're saying very little to me (other than highlighting my inexperience in reading these kinds of things). Whether my questions are significant or not is likely a relative notion, but I would appreciate some help with the following:
1. The graph seems to represent speaker response for a box volume of 3.666 liters and other than having relatively little bass it looks like a fairly desirable straight line to me. Is the lack of substantial bass supposed to stand as a self-evident argument against using sealed enclosures with this type of speaker (since more desirable results can be obtained with non-sealed enclosures)?
2. Can the response provided here be assumed to follow for cabinets of different (e.g. larger) volumes, or only for the volume specified? What would happen if the 10p was placed in a larger volume, or is the specified volume presumed to be ideal for the 10p in a sealed enclosure?
3. Lastly, to put my ignorance fully on display here, why does the graph show four sets of lines (four black, four yellow, and so on)? Is this supposed to represent a range of likely results (almost like a probabilistic range) or is it something simpler and more mundane?
Old 2nd December 2013, 06:44 PM   #128
frugal-phile(tm)
planet10's Avatar
Originally Posted by Philosophil View Post
Could someone help interpret the above graph for me? I assume it means that the bass d150 Hz)rops off at around 100hz, but is there anything else that is significant here?
Simulation of the sealed box response with Qs of 0.5, 0.58, 0.707, 1.0 (bottom to top at 150 Hz). Box volumes required in the table bottom right, speaker info bottom left.
dave
Old 2nd December 2013, 06:49 PM   #129
dave
That helps. Thanks.
Old 2nd December 2013, 07:00 PM   #130
frugal-phile(tm)
planet10's Avatar
Box volume scales as Q decreases. Practical alignments are usually between 0.58 and 0.707, 0.5 and 1.0 represent the max & min size volumes that one would use. Adding damping (to a certain point) decrease the system Q (ie increase the apparant size of the box)
Scales are on the right (and left for phase) of the chart, legend below the scale (Excursion/Delay/Impedance). Note that the phase scale has been cut off the !10p)
dave
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 04:37 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 06:04 AM
Ar 10p ??? jovan Multi-Way 0 6th January 2005 08:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
