Alpair 10P: Preview - Page 10 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 9th July 2013, 07:38 PM   #91
Bob Brines's Avatar
Originally Posted by suburra View Post
The Harmann BR has about the same volume I calculate to any A10, but the port will need shortening, particularly for the A10P. That is going to be very hard to do. The A10M in that box will be quite underdamped. However, it costs you nothing to try them.
I can't speak to Dave's Mar-Ken, but It looks very hard to modify after closed up and finished.
Bob
Old 9th July 2013, 07:50 PM   #92
chrisb is offline chrisb  Canada
Bob
well, if built exactly per drawings (and without nails/screws) , one could always chop/route off the bottom to resize the port slots (yes, I've modified enclosures thus) - but all in all it might be easier to build another pair of boxes
now on sabbatical
Old 9th July 2013, 08:27 PM   #93
suburra is offline suburra  Italy
Hi
@ Dave
Thank you for reply, i will wait yours design, hope for good news
Because the back of cabinet is removable, so it's possible to workin inside
@ Bob
Thanks Bob, i will try to do like chrib said if needed
and for other project (knowing the right measure of port) will try, because the back of this cabinet it's not removable, so will be very hard to workin inside
@ chrisb
Thank you for tip
Marco
Old 9th July 2013, 08:37 PM   #94
This is my GR Marken
View image: IMGP0292
Old 9th July 2013, 08:41 PM   #95
Other view
View image: IMGP0290
Old 9th July 2013, 09:09 PM   #96
Bob Brines's Avatar
Hi
@ Dave
Then you should be home free. As soon as Dave decides the correct port length, you open them up and saw, sand, file the port down to the required size.
Bob
Old 9th July 2013, 09:24 PM   #97
suburra; nice work - particularly on the bracing
now on sabbatical
Old 9th July 2013, 09:33 PM   #98
Thank you
has been a long and complicated work for me
for this reason I prefer try to mod this rather than rebuild
Marco
Old 9th July 2013, 09:43 PM   #99
frugal-phile(tm)
planet10's Avatar
Easy enuff to tune lower. To tune higher is not as straight-forward, doable in practise, but depending on the situation maybe not practical (see what we did for our Em-Ken mules to tune higher -- a lot of saw-dust was made.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th July 2013, 09:45 PM   #100
frugal-phile(tm)
planet10's Avatar
Those could easily be tuned higher, even with just a drill and a big bit (but only because the back is removable).
dave
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 04:37 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 06:04 AM
Ar 10p ??? jovan Multi-Way 0 6th January 2005 08:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
