My odd little FAST with chr-70.3 build - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 17th April 2013, 02:28 AM   #1
satx is offline satx  United States
Default My odd little FAST with chr-70.3 build
Thought I'd share my strange little fast build with you. I say strange because I know implementing a full range driver in an open tunnel/open baffle and a small woofer in a small volume enclosure, all stuffed into a standmount size speaker isn't really the normal path one would take. Surprisingly, they do sound quite good though! Really as good as I had hoped.
I had had the Chr-70.3 in a 9L BR which I was very pleased with, but I just can't resist the urge to play and as of late I have been becoming more and more intrigued with the FAST concept. Plus I had actually built the small BR for the chp-70.2 and they were sitting around homeless. The extended range of the chr's and the fact that they seemed to lose their composure a bit when pushed started me thinking of trying a fast with them.
I wanted to make it a medium sized standmount, because I already have too many floorstanders kicking around my house. This creates quite a problem because it's a little hard to make much bass from a standmount and even worse with a good chunk of the enclosure is being taken up by a full range driver instead of a small tweeter. My woofer options were limited because not many are going to do well, bass wise, in these conditions, plus I wanted to keep the cost pretty low because I wasn't at all sure that this would work. I finally settled on the sb13pfc25 5" because it modeled pretty well was cheap and had a bit better sensitivity than the MA.
So, to try to make this long story short, I have a sb13pfc25 in 8L and a Chr-70.3 in a open back tunnel mounted above it in a mid size bookshelf speaker. crossover is at 400hz with a damped 2nd order on the woofer and just a cap and l-pad on the full range. Oh, I also used a small inductor in series with the FR to shape the top end. I don't know why, but thing like cymbals were very forward. I really didn't have this problem when using this driver in a BR.
Evan
Old 17th April 2013, 02:47 AM   #2
And... here are some pictures
Crap! for some reason I always have problems uploading photos here. So only a couple at a time.
File Type: jpg Tunder cat speaker build for diy 002.jpg (581.2 KB, 324 views)
File Type: jpg Tunder cat speaker build for diy 001.jpg (717.4 KB, 305 views)
Old 17th April 2013, 02:51 AM   #3
and more
File Type: jpg Tunder cat speaker build for diy 005.jpg (249.8 KB, 281 views)
File Type: jpg Tunder cat speaker build for diy 006.jpg (234.9 KB, 268 views)
File Type: jpg Tunder cat speaker build for diy 011.jpg (457.4 KB, 264 views)
Old 17th April 2013, 03:01 AM   #4
and...
Old 17th April 2013, 03:18 AM   #5
And finally, here is the last of them. They turned out pretty good in my opinion. Being able to paint over any construction flaws makes for a less stressful build than using Ply even though the prep work is a pain. They sound very good to me; really I achieved more or less exactly what I was trying to with these. Relieve the Chr from producing bass to clean-up the midrange even further, they are quite nice all by themselves. Also, maintain or improve upon the bass from the Chr in a BR cab, hard to say here, but they have very good bass with more impact/feel and seemingly the same extension. Unibox shows f3 of 52 hz and f10 or 35 hz well damped box tuned to about 49hz. I don't have measurement equipment except for impedance. Minimum impedance 5.6 ohm @ 150hz, otherwise it stays above 8 ohms.
Thanks for looking. Comments or suggestions are very welcome.
Evan
File Type: jpg Tunder cat speaker build for diy 0181.jpg (703.0 KB, 95 views)
File Type: jpg Tunder cat speaker build for diy 014.jpg (514.0 KB, 61 views)
Old 17th April 2013, 05:00 AM   #6
frugal-phile(tm)
planet10's Avatar
Those look nice.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th April 2013, 05:10 AM   #7
Thanks Dave. I have gotten a lot of good information from your post on here
Evan
Old 17th April 2013, 05:36 AM   #8
TiMBoZ is offline TiMBoZ  Australia
Nifty! I like it - for me, it's a fun concept of wide range goes rock 'n' pop, without going all serious with subs etc. Good on ya!
damped 2nd order
Can I ask what are you referring to by 'damped'?
Old 17th April 2013, 05:47 AM   #9
Thank you!
Sorry, something I heard from someone else on here, not sure if it's a technical term
It's a resistor in series with the woofer's parallel cap. I was getting an impedance dip to maybe 3.5 ohms at about 100-200 and a corresponding audible whomp sound in that region. The resistor brought it up more in line with the rest of the frequency.
Old 17th April 2013, 05:57 AM   #10
Oh Ok yep thanx.
It's like an itch, I'd like to do one with an A7 someday. You just made it itchy again.
markaudio chr-70 gen 3 build dnic77 Markaudio 11 30th March 2013 04:17 AM
My CHR-70 build SirByrd Markaudio 13 14th March 2013 11:24 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
CHR-70 for a first time build gideon Markaudio 4 26th October 2010 04:22 AM
Mark Audio CHR-70 in my FAST..... speakrsrfun Full Range 9 31st March 2009 04:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
