Alpair 10 Generation 3 - metal cone - Page 4 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 16th April 2013, 07:17 PM   #31
cogitech's Avatar
Originally Posted by chrisb View Post
I thought I was chuffed about this driver before - sign me up
Indeed. I already know precisely what I am doing with my pair.
Old 16th April 2013, 10:48 PM   #32
Scottmoose's Avatar
Originally Posted by larryldspkr View Post
Exactly what are the arrestors and how do they work?
NEWS: Markaudio driver up-grades
Old 16th April 2013, 11:43 PM   #33
Thank you Scott, question answered!
Larry
Old 28th April 2013, 12:47 AM   #34
Are there any changes to the A-10 Pencil for the A-10.3 Metal?
Old 28th April 2013, 01:52 AM   #35
frugal-phile(tm)
planet10's Avatar
Guys, until Mark actually finishes the design and gets us measures from production, how can we look at the box designs... patience.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th April 2013, 02:07 AM   #36
markaudio's Avatar
Guys,
I'm planning to be at the factory this Wednesday to complete testing of early production batches of drivers. I'll be posting the final data later this week to early next.
Mark.
Old 29th April 2013, 10:19 AM   #37
Scottmoose's Avatar
Excellent. Thanks Mark. Will try to get a pensil for the new boxes sorted out fairly quickly. On the positive side, this shouldn't take too long given I've got my design sheets mostly automated now for a variety of alignments, including these.
Old 29th April 2013, 02:09 PM   #38
Scott,
Any chance of designing the Pencil enclosures to be a little taller with the driver at a higher point away from the floor? Would it be possible to have the driver around 30 - 34 inches / 75 - 85 cm above the floor?
Bill
Old 29th April 2013, 02:37 PM   #39
Scottmoose's Avatar
It depends on the driver. The pensils are designed to a specific alignment, so axial length depends on the driver's characteristics to hit the target response. As it happens, the 10.2 box was a compromise; I would have made it taller under slightly different circumstances, which are no longer applicable. The 10.3 box might end up being taller, it might not, depending on the final production EM spec. of the new unit.
Old 29th April 2013, 02:43 PM   #40
Interesting. And an interesting coincidence that the 7.3 and 10.2 Pencils were the same height. I thought maybe your model had a fixed height and width dimension and varied the depth based on the T/S numbers.
Bill
Visual on Frequency Generation off Cone, Dust Cap and or Whizzer kach22i Full Range 5 13th February 2011 05:32 PM
Alpair 10 - Generation 2 - sneak peek markaudio Markaudio 108 11th November 2010 07:20 AM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 11:37 AM
Metal dome should always go with metal cone? Is this a rule? Jay_WJ Multi-Way 5 5th February 2007 06:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
