Alpair 10 Generation 3 - metal cone - Page 11 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 2nd August 2013, 10:47 PM   #101
Default 10.3 compact bass reflex build
Received my 10.3 drivers from Mark a couple weeks back and couldn't wait to make cabinets for these. First Mark Audio drivers i've ever had. This is the end result, sound is really fantastic.
- Volume is approximately 15L after deducting for cone volume, port volume and a single brace.
- Width of the speaker is 22 cm, Height 40 cm and Depth 28.5 cm.
- Bass reflex port is sighted on the underside, internal diameter 64 mm (standard gutter pipe) length 22cm for tuning to 49 Hz according to WinISD.
- This should give -3dB at just under 50 Hz.
- 18mm MDF used throughout apart from the front panel, 25mm MDF.
- Rubber feet raise the cabinet 20mm off the table, allowing bass reflex to operate satisfactorily.
- Finishing used Zinsser 123 primer and automotive top coat.
More photos of the build from start to finish can be viewed at:
Mark Audio Alpair 10.3 Compact Bass Reflex Speaker Build | Mister Wireless
**Thanks Mark for making these nice drivers for the diy people.**
Old 2nd August 2013, 10:51 PM   #102
StevenZ is offline StevenZ  United States
Very nice, those turned out great!
Old 2nd August 2013, 10:58 PM   #103
Very, very nice!
Old 3rd August 2013, 03:48 AM   #104
doorman is online now doorman  Canada
doorman's Avatar
Excellent !
Very nice tidy package.
As mentioned elsewhere, these drivers take a while to really sound their best.
Don
Old 3rd August 2013, 12:28 PM   #105
Thanks for the kind comments!
Old 3rd August 2013, 02:53 PM   #106
larryldspkr's Avatar
Nice job! I've had alpair 10.1 and 10.2's and enjoyed them very much. They just keep sounding better and better, even after 6 months of playing! ENJOY!
Larry
Old 26th October 2014, 03:07 PM   #107
Hi everybody I 'm french and new
I have a pair of JX92S in mltl 31'' enclosures but my children have damaged the speakers.
I'm very interested in this new Alpair but do you think it would be good in my cabinet
THanks
Old 27th October 2014, 07:42 PM   #108
chrisb is online now chrisb  Canada
It might be hard to get the 10.3s to "not work" in the strictest sense, but the enclosure might not be optimally tuned for them.
Note that the Alpair metal cone drivers are not likely to be any more rugged in terms of physical abuse than the Jordans - while the 10P papers could well be.
now on sabbatical
Old 20th November 2014, 08:53 AM   #109
JoeyGS is offline JoeyGS  Philippines
Has anyone compared the 10.3 with the 10p on pensil box?
The 10.3 as per specs seems to have a lower bottom end but the 10p is easier to drive at 89db.
While I have heard that the 10p is very good, but as Mark has intended the 10.3 to be the big brother of the 7.3, I am wondering if the 10.3 is better than the 10p using the same type of box.
Old 20th November 2014, 09:45 AM   #110
I wonder if we could do a simple poll, Alpair, best for., bass dynamics, vocal etc...and each rate, this question has been asked so many times, and depends on so many factors, the only real way to say is personal evaluation.
Can we do a poll?
Visual on Frequency Generation off Cone, Dust Cap and or Whizzer kach22i Full Range 5 13th February 2011 06:32 PM
Alpair 10 - Generation 2 - sneak peek markaudio Markaudio 108 11th November 2010 08:20 AM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
Metal dome should always go with metal cone? Is this a rule? Jay_WJ Multi-Way 5 5th February 2007 07:53 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
