alpair 10.2 accidental damage .... need advice - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 31st March 2013, 05:45 PM   #1
manud is offline manud  India
Default alpair 10.2 accidental damage .... need advice
Hi ,
I am in the middle of my first diy speaker cabinet and I accidentaly dropped my LN key on the speaker diaphragm . I have attached pictures of the damage .
There is an indentation on the lower side of the speaker .
I do not see a tear/ crack there .
But assuming if it is , is the speaker gone ?
Need advice if it is serious damage ? what I can do about it ?
Manish
Old 31st March 2013, 06:45 PM   #2
Jozua is offline Jozua  South Africa
Hi
I think you should be fine.
Just do not try and repair it.
Jozua
Old 31st March 2013, 06:51 PM   #3
Thanks .But just for information , assuming if there is a small tear / crack . what are the options really ? i cannot play loud and with usage there tear will become bigger ?
Is there anything I could apply which would not make the crack bigger ? like some silicon glue , or anything else ?
Manish
Old 31st March 2013, 09:29 PM   #4
larryldspkr's Avatar
I would suggest that you DO NOTHING, and enjoy your speakers despite this small blemish!
Larry
Old 1st April 2013, 02:52 AM   #5
markaudio's Avatar
Hello Manish,
Alas accidents happen. Looking at the damage from your pics, it is minor so don't panic! The driver will function Ok provided you operate it under normal full-range service conditions (don't over-drive it)
You could choose to do the following:
1 - Do nothing, leave the ding alone.
2 - Using your index finger (making sure your finger nail is Not sharp), VERY Gently rub the back of the cone to push the ding out. Take your time doing this. With care you'll push 90% of the ding out.
I'm well skilled at getting dings out, its your first time so Don't rush it. Just work on the affected area with your finger nail.
Cheers
Mark.
Old 1st April 2013, 03:20 PM   #6
Thanks Mark . I am leaving it as it is . I am hoping to listen to it soon, so do not want to risk more .
Manish
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
alpair 10 nearfield? need advice human.bin Full Range 7 11th February 2010 10:42 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
