Alpair 8 - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 26th February 2013, 12:24 PM   #11
Scottmoose's Avatar
And another one: options for both 8ohm and 4ohm VCs / powertrains.
Old 26th February 2013, 12:27 PM   #12
Scottmoose's Avatar
And another. No doubt there are some who would like different cone options, e.g. metal and paper.
Old 27th February 2013, 12:08 AM   #13
JohnLL is offline JohnLL  United States
Yes paper and bass even at the expense of efficiency. Also nice big BSC frequency response curve like the A10. I would like something that works real near field all by itself.
Old 1st March 2013, 05:09 AM   #14
Default Impedance 10-12-16 ohms?
It seems that many small tube amps may be a better match with higher impedances so how about some higher impedance options?
Old 1st March 2013, 05:37 AM   #15
markaudio's Avatar
Hi C,
You sure? Please further explain and demonstrate your thinking.
I seem to remember a conversation with Brian Cherry (Diy Hi Fi Supply) some years back where he said lower and flatter driver impedances where a better match for most valve/tube amps.
Granted, my amp knowledge is based mostly on feedback from amp makers and end-users. So I'm open to alternative thinking on this subject
Cheers
Mark.
Old 1st March 2013, 06:00 AM   #16
Default higher impedance
Sure Mark. I'm not an amp expert, just an audio enthusiast and occasional DIY'er. My comments are based on a discussion with a maker of OTL amps I own who related that there are amps (not just his own) that generate more power and less distortion into higher impedance loads. May be worth while to solicit some input from a few amp makers.
Old 1st March 2013, 07:30 AM   #17
hajj is online now hajj  Lebanon
hajj's Avatar
I'm no expert here, but I think that OTL amps are a special as they rely on matching the amp's output impedance to the driver's impedance in order to extract maximum power.
As opposed to most other amps that match their OPT to a specific driver impedance.
Old 1st March 2013, 05:08 PM   #18
chrisb is online now chrisb  Canada
well, few drivers (except for some planar types) have impedance graphs that are linear throughout their bandwidth when measured with test tones, so the "matching" between load and output stage is nominal at best
then there's that intimate feedback dance between the two ( I like to think of it as an Argentinian Tango) that happens when you start reproducing complex dynamic waveforms
while we're at it, just as an exercise in consensus building and polite conversation, let's discuss damping factor
no, let's not
that aside, many amplifier designs tend to suffer less distortion into higher impedance loads, even when operating well below maximum output levels
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 4th March 2013, 11:24 AM   #19
hajj's Avatar
no, let's not
"Consensus building in discussing damping factor", one of audio's biggest oxymorons
thanks for the info
Old 30th March 2013, 01:39 PM   #20
Bill poster's Avatar
This sounds like a perfect size, to me. I cd use a pair of these right now for a current project.
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 07:21 PM
Alpair 6p vs alpair 6m vs alpair 7 timreeves Markaudio 11 8th January 2013 03:37 PM
Alpair 12en in BIBen cabinet or Alpair 7 in fonken w/subs tripathdude Full Range 1 7th November 2010 05:04 AM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 06:14 AM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 11:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
