Dumb Question? Alpair Terminals - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 28th January 2013, 03:41 PM   #1
cogitech's Avatar
Default Dumb Question? Alpair Terminals
I searched but apparently I am the only one who can't figure this out?
How the heck am I supposed to use the Alpair connection terminals?
Old 28th January 2013, 04:27 PM   #2
Scottmoose's Avatar
I find attaching wires helps.
Joking aside, what is the specific problem you've got? Attaching? Positions? Something else? Sorry, I'm half asleep this afternoon.
Old 28th January 2013, 04:33 PM   #3
cogitech's Avatar
What's the point of the 3 pieces?
I slid it apart and the copper piece fell out. Getting it back together was a PITA.
What's the point of it? How is it any better than a basic male spade connector?
There must be some reason why Mark designed it this way, and I am completely missing the point.
Old 28th January 2013, 05:05 PM   #4
toobhed is offline toobhed  United States
I think one of the objectives might be avoiding solder heat on the driver's voice coil. This is accomplished by only soldering the wire to the piece of metal that isn't attached to the driver, and then later slipping it against the metal attached to the driver and holding the two in place with the plastic attacher. If the plastic holder isn't tight enough to hold the two metal things together, try reversing the one attached to the leads.
Mario
Old 28th January 2013, 05:06 PM   #5
I'll take a few pics when I get home and post if you'd like.
Old 28th January 2013, 05:32 PM   #6
chrisb is offline chrisb  Canada
I quite like the hex screws that Mark supplies, but avoid using the terminals altogether, and just solder directly to the speaker's tab. If you pre-tin the wire and lightly crimp or fold it over, it shouldn't take long enough to complete the solder joint to risk any damage - I counted about 3 seconds with my Weller iron set to 750F and using Cardas Quad Eutectic (luv that stuff)
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 28th January 2013, 05:36 PM   #7
frugal-phile(tm)
planet10's Avatar
The intention is that if you are using welding cable sized wire (not recommended) it avoids melting the plastic holding the fixed terminal.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2013, 06:46 PM   #8
cogitech's Avatar
Thanks everyone.
I don't solder onto the tabs, so they offer little value to me.
At least I know why they are the way they are now.
Cheers.
Dumb question? Phil Olson Multi-Way 3 23rd October 2009 07:52 PM
Dumb question, but... johnm Tubes / Valves 3 13th June 2008 10:14 PM
Dumb question. G Tubes / Valves 2 16th January 2008 08:16 PM
dumb question: what does a baffle do? cuibono Multi-Way 5 17th September 2007 06:08 AM
maybe this is too dumb a question... dannyspencer Solid State 6 18th April 2004 04:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
