What amp for Pensil 10.2? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 24th January 2013, 04:38 PM   #1
dekiller's Avatar
Default What amp for Pensil 10.2?
I've a digital amp, a 6CA7 SE, and a 6V6 SE. I found the least-power 6V6 SE sound best on my setup. Just want to know what amp is used by other users.
Old 24th January 2013, 05:24 PM   #2
I only use Herron M150 amps with the latest mods. I just haven't heard anything better. Or even as good, frankly. Fabulous dynamic snap and detail. Very flat response, no coloration. Vanishingly low distortion.
That said, I'm not using Mark Audio drivers yet. Still in the planning stages. But good amps are good amps.
Old 24th January 2013, 06:10 PM   #3
chrisb is online now chrisb  Canada
indeed, but never underestimate or discount the synergy (or antagonism) that can occur between components - for example ask Jim Shearer about his experience with F120A
re the 10.2 - I've heard them blossom with a 2A3, which on paper might not be sufficient power for theatrical dynamics and realistic concert level SPLs
I don't currently live with a pair (10.2s) , but my choice in a small room would be something like the 6CA7 SE - as it turns out, one of the members of my "harem"
now on sabbatical
Old 24th January 2013, 08:23 PM   #4
TiMBoZ is offline TiMBoZ  Australia
I like the sound of that...How do I get a "harem"
Old 24th January 2013, 10:03 PM   #5
Chris,
It's been my experience that problems upstream cannot be fixed downstream. Amp shortcomings may be masked by other weaknesses in the chain, but they don't disappear.
"Warmth" in amps sometimes creates a sweeter, more romantic presentation, but it doesn't take away from the fact that it is a distortion.
BTW, I've heard some low power SET amps perform as if they had a LOT more power. Not sure why, but the dynamics were certainly eye-opening.
Old 29th January 2013, 04:07 PM   #6
Bruce Rozenblit in his "Tubes and Circuits" book posits that the reason tubes seem to have more power is that the semiconductor materials used as cathodes in tubes are able to handle brief 1-2ms transients at more than 1000x the steady state power handling. This works well for music, since typical higher power notes are short.
Old 29th January 2013, 06:03 PM   #7
let's not let this devolve into another of those SS / vs HollowState debates - each type has its own merits -there is no "best" or "one amp for all"
although I must say that the most transparent, lyrical, dynamic, musical devices I've yet heard was a hybrid design by Rene Jaeger - 45 DHT driving some type of SE FET output stage - it's very easy to get lost in the music and not really hear the technical description of the design (of course it'd still be geek to me)
"harem" - I'm was in the middle of reading "Enchantress of Florence" (Salman Rushdie) when I typed that - forum decorum precludes elaboration
now on sabbatical
Old 27th February 2013, 05:18 PM   #8
OlavHaal's Avatar
Thumbs up Hi - here are someone wise....
Hi to all!
Look at this site - seems like they are using Alp10.2 and in a no-wood cabinet. Still it is favorably compared to Sonus Faber Cremona Auditors and Proac Tablette Ref8, and it even plays better than those 2 in some aspects.
CA-Electronics Sound Quality | CA Electronics AP-10 bookshelf speaker
CA-Electronics AP10 Loudspeakers | Hifi Pig
So our wood-boxes with Alp10.2 should give even a more harmonius sound -maybe.
And my new Alp12P - is even more tonally rich in a somewhat equal box!
So - Mark - your way of producing these fine sound-pieces is really giving us diyr a perfect opportunity!
Thanks and Best to all!
Olav
Old 28th February 2013, 12:40 AM   #9
markaudio's Avatar
Hi Guys,
Thanks again for messages of support and encouragement. When it comes to amps, I a bit of a swopa-holic. I've ran Pensil 10's on the following amps with pleasing results:
For absolute precision: http://www.accuphase.com/cat/e-308_e.pdf
For warmth (I have 2 of these 300B's, one with vintage C type Mr Zhu trans, the other with Kenneth's trans - both yummy: Tony's 300B (standard model)
For slam and presence (go easy on the vol): SANSUI ƒvƒŠƒƒCƒ“ƒAƒ“ƒvAU-ƒ907DR‚Žd—l ƒTƒ“ƒXƒC
For smooooooothness: SONY ƒvƒŠƒƒCƒ“ƒAƒ“ƒvTA-F333ESX‚Žd—l ƒ\ƒj[
There's a few more combo's but they're in the studio, will need to visit later next week as I'm working from home while recovering. I'm also using DIY-Hi-Fi Supplies Django coupled to the later 300B with much pleasure
One thing that I believe is most important: source. I use an Accuphase DP67 CD player as my reference source. I'm also very picky re CD's.
Overall, I tend to learn towards Tony's 300B's and other tubies. However, all my Mofs are "all Japan" models, tweaked, running on clean voltage (100v to 220v) converters so they aint your average product. I'm in no rush to give these solids away!
Hope this helps,
Mark.
Old 28th February 2013, 03:05 PM   #10
dekiller's Avatar
I have just ordered a DIY Pass Alpeh Mini to work with my Opera T1 pre-amp (modified). What do you think?
Mar-Ken10.2 & Pensil 10.2 grimmrok Full Range 42 30th December 2012 10:24 PM
First build ever: Pensil 10.2 - in solid oak Swifty Markaudio 37 4th March 2012 04:52 AM
Ryan's Pensil 10.2 Build Log CabinetMakerRyan Markaudio 90 21st January 2012 12:33 PM
Pensil 10.2 build: Vent location? Swifty Markaudio 9 13th June 2011 07:01 PM
Illegitimate Son of Pensil - Alpair 10.2 buzzforb Full Range 135 25th April 2011 07:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
