subwoofer augmentation for alpair 10.2 - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 6th May 2013, 11:41 PM   #41
Originally Posted by planet10 View Post
You'd need to high pass the 2A3 for that Kind of gain
dave
Are there any downsides to doing this?
Old 7th May 2013, 12:47 AM   #42
frugal-phile(tm)
planet10's Avatar
Depends on how you are setting stuff up.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th May 2013, 04:48 PM   #43
Originally Posted by soundnovice View Post
after understanding the relation of 'emmittance' and cone size, one possible solution thats popping up is to go for smaller subs(say 6") in an array(say 4 per side). as per my knowledge, this could effectively have acceptable higher SPLs at lowbass range,total air volume moved and still maintain that dynamics. if i am not wrong, may not need huge power also and could get away with max. power supported by the drivers(say 200W max). need to look at other issues such arrays would pose though. anybody tried this?
here we go!
Pair of EVO Active Bass Modules (ABM's) Including Cabinet Linking Cables
anyone have experience with this?
Old 18th May 2013, 05:36 PM   #44
After listening to a pair of Alpair 10.2s in Pencils in nearfield, I'm not sure a subwoofer is necessary. In fact, depending on room placement, box stuffing, listening position and the rest of the system, there actually may be more bass than what one hears in a natural acoustical environment (such as Powell Hall in St. Louis). There is adequate deep bass (for me in my environment and set-up) to round out an orchestral performance. In the nearfield listening experience (with an optimized room set-up) there is also quite adequate dynamic headroom.
I suppose that users could bi-amp in a good subwoofer, but I would not bring it in above 40hz if the 10.2s are in Pencils. YMMV.
(Written as I attempt to squeeze into my flameproof suit and crash helmet.)
Old 18th May 2013, 06:20 PM   #45
the motivation behind looking to augment sub with alpair 10.2 is to 'relieve' the alpairs from the stress below 80hz (where cone excursion is evident) and let it handle the rest of the band with ease.
Old 18th May 2013, 06:40 PM   #46
vinylkid58's Avatar
Then why bother with a MLTL style box at all, if you're going to high pass them with an active/passive filter? A smaller BR box would be a better approach.
jeff
Old 18th May 2013, 06:51 PM   #47
chris661's Avatar
I'd argue against using lots of small drivers to replace one big one, unless a high aspect ratio cabinet is desired.
My reasoning is this:
4x 6" woofers is not the same as a single 12" woofer.
They might have the same cone area, but a decent 12" woofer can move, say, 12mm one-way.
Now ask those 4x 6" woofers to do the same.
Asking 6mm one-way travel of a 6" woofer is, IMO, more like it, but still excessive. But now you need 8 of those 6" woofers to match the SPL capability of the 12", and I'd still expect similar distortion figures.
Chris
No longer a teenager.
"Voice coils are so 1915!" - Andersonix
Old 18th May 2013, 06:53 PM   #48
jeff
yes. currently they are in small vented box only!
however i will still go for MLTL box. i will switch to sub+MLTL for movies and certain kind of genre where lows are expected. other times i will bypass sub and enjoy soft music with just the MLTLs!!
Old 18th May 2013, 10:12 PM   #49
That was my thought originally. I changed my mind after listening to them and finding the right room placement to get the best bass performance. I have some very good subwoofers that I might use, but I'd probably still run the 10.2s full range and just add the subs below 30hz or so. I don't think I want any additional electronics or crossover components in the signal path of the 10.2s.
I'd look harder at room placement and seating position rather than just throwing a sub at them.
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Markaudio 56 3rd March 2014 08:21 PM
Subwoofer for Alpair 10 Gen.2 Alex_77 Markaudio 1 25th March 2011 07:48 PM
Alpair 10 more forgiving than Alpair 7 & 12 tripathdude Full Range 3 6th November 2010 07:14 AM
Alpair 10 Bass + Alpair 5 - Woodwill Japan markaudio Markaudio 16 26th January 2010 12:48 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
