Alpair12P build possible suggestions? - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 20th January 2013, 07:25 PM   #1
Default Alpair12P build possible suggestions?
Hi All,
I've recently been reading about the fullrange drivers on the interweb and couldn't resist purchasing a pair of 12p. I finished a mini DSP 2 way with B&C drivers and 2 subwoofers just because I could. Then moved to a small place and had to down size. Even I would like a smaller footprint.
Anyways, to the question. My listening space is roughly 8 X 7 meters and I'd like as small as footprint as possible without giving up much in performance. I know, the eternal question.
Do you experienced 12p builders suggest the pensil or superpensil build for this space? I do not want to use a subwoofer because of the extra footprint, but maybe the regular pensil with bass augumentation is the way to go?
Side note, I have roughly 40 hours on breakin on these so far. Parts express 0.75 cubed feet box ported to around 58hz with topping tp60 as my interim setup. I've had to rethink my views on dynamics with these drivers. They continue to improve and don't feel the need to suppliment the high end. I'm having a tough time keeping the hand away from the increase volume button.
Any suggestions on box type outside of the above is also welcome. Thank you in advance.
Old 20th January 2013, 07:48 PM   #2
vinylkid58's Avatar
That's a good sized room. I'd build SuperPencils if the box size appeals to you. Woden Avebury would be really cool, but a much taller and more complex build.
http://www.wodendesign.com/avebury.html
jeff
Old 20th January 2013, 08:15 PM   #3
Thanks for the info Jeff. I will definitely take a look at that design. My initial thinking was the SuperPensil as well but dosen't hurt to take a harder look at all the options, especially since I'm a flip flopper.
I think the 12P will be in the room for an long while so I'm hoping to avoid building multiple enclosures.
I'm starting to understand why some people have such strong feelings regarding fullrange drivers. The Avebury is definitely larger, wow!
Do you feel there is a large difference in extension between the enclosures in a real room environment (of course trying to exclude major room variables)?
Thanks,
Mike
Old 20th January 2013, 08:30 PM   #4
vinylkid58's Avatar
Not having heard the Aveburys, I can only speculate that they could sound very impressive, based on my limited exposure to other smaller Woden designs.
jeff
Old 20th January 2013, 08:53 PM   #5
TiMBoZ is offline TiMBoZ  Australia
Yeah! I like the Woden Avebury for the A12P. It looks an impressive design, but not for the feint of heart. Not the most practical design, but if I had the scope/room for it - I'd love to try that myself someday. I'd just wanna make sure it didn't topple on anyone. But I think it would work great with the A12P.
Old 20th January 2013, 09:16 PM   #6
Good point. I'd probably have to fix the tops to the wall as these will be sitting on carpet. They would be nice to hear for comparison though.
Old 20th January 2013, 09:46 PM   #7
If you didn't wanna make holes in ceiling, the design could lend itself to some kind of buttress or 'outrigger' type feet to increase the footprint/increase stability. Imagine a couple of half-cylindrical fins/buttresses running down either side - similar to fins on a rocket, tapering towards the top, wider at the bottom. This would also help break up the boxy appearance. It would be a pretty 'committed' build. But end result would be impressive.
Old 20th January 2013, 10:38 PM   #8
frugal-phile(tm)
planet10's Avatar
A12p is good in about 10-20 litres for a typical vented box. To extract more bass a TL (like the Pensil) or a horn (like Avebury) are needed. You have a pretty big room, Avebury would be stunning. Outriggers with spikes would solve most stabiliy issues.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th January 2013, 10:57 PM   #9
vinylkid58's Avatar
I can see the headlines now, "party-goers crushed by giant speakers".
jeff
Old 21st January 2013, 01:21 AM   #10
Thanks for the info guys! Sounds like the Avebury or large TL might be the definitive answer to the space. I'll have to do some more research but its starting to sound like the SuperPensil is a minimum enclosure size for this room if no sub is to be used. The Avebury is a bit ambitous for me right now and I don't want to crush my guest with 73" slab of wood!! Although..........
After the SuperPensil I might take my time and build the Avebury. Thanks for the suggestions, it is what was needed to make the decision.
Looking forward to maximizing this driver, it deserves it!
Best Regards,
Mike
Alpair12P gen2 standmount speakers Toppsy Markaudio 195 20th September 2013 02:24 AM
Suggestions for a build. Alexontherocks Class D 8 24th June 2011 03:08 PM
First Build - Suggestions? K5Doom Multi-Way 11 2nd March 2011 07:21 PM
Need some suggestions on what to build. morphon Full Range 14 17th November 2008 05:05 PM
I'd like to build a 3-way. I could use a few suggestions. Thanks. mpmarino Multi-Way 6 26th February 2007 05:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
