| Markaudio Designers and builders of audiophile grade drivers |
So I was tightening down the supplied screws and one of them cause the ring to crack as shown in the picture. Does that happen often? Should I not have use the supplied screws? It seems that the screw heads were a bit larger than the hole or something because it cracks even before the driver is completely mounted firm against the baffle.
#2 | |
The screws we supply are custom made, with smaller heads than the frame hole recesses. We only make and supply 1 size of screw for the Alpair 7. From your description of events and looking at the pic, the screws weren't properly centred within the frame plus heavy over-tightening caused the failures. With pressed steel and composite frames, care must be taken to properly align the the mounting holes; And gentle tightening is all thats required. I suggest carefully undo the drivers, get some suitable A/B bond or super-glue and apply it to the cracks. Assuming you've kept the front covers, bond them on for added strength. Then carefully double check the screw hole alignments. Make sure their centred to the holes in the driver's frame. Drill small 2mm pilot holes in the box should you wish to turn the drivers to make new mounting on the box. Place the driver in position and use a 4-mm drill or punch bit inside the frame holes to mark the pilot hole positions. Don't murder the screws when tightening down on to the frame. Be gentle and use a hand tool for this process. You'll get to feel when the screws is taken the frame tight on the baffle. Make 100% sure your baffle mounting surface if flat. With luck, you'll save the drivers and live to play another day. Cheers Mark Last edited by markaudio; 17th January 2013 at 09:55 AM. |
| faraday ring shape ?(shorting ring) | guitar89 | Construction Tips | 2 | 9th September 2011 09:38 AM |
| Noob Question: What is the second mounting ring for in my Alpair 7? | pizzachef | Markaudio | 2 | 24th August 2011 12:44 AM |
| cracked plastic gear | thomash85715 | Analogue Source | 0 | 14th May 2007 07:19 PM |
| about the shorted ring (flux stabilizer ring) | haggy | Multi-Way | 3 | 4th January 2002 02:04 AM |
