Tower speakers for HT front and surround speakers (using CHR-70A) - Page 2 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 29th November 2012, 10:01 PM   #11
chrisb is online now chrisb  Canada
Originally Posted by nowobody View Post
I'm aware of that, too. just in case the CHR is not big enough to cover my space, going for the bigger drivers is neccessary.
(I will get to this space after my other room anyway, so I can try it out ffirst before building this set later.)
As Dave alluded in a previous post, until the T/S params for this new (special issue?) driver are known, it's rather a bit of conjecture to recommend particular enclosure style and number of drivers per each for this application.
Also note that whenever HT or 5.1 (or beyond) are mentioned, I think a lot of folks (myself certainly among them) assume employment of powered sub(s) that would permit the use of smaller drivers that are more readily accommodated in "skinny towers", or small wall mounts (such as the splayed surrounds mentioned in your other thread)
now on sabbatical
Old 30th November 2012, 12:01 AM   #12
frugal-phile(tm)
planet10's Avatar
Or multiple CHR
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th November 2012, 02:03 AM   #13
Originally Posted by planet10 View Post
Or multiple CHR
dave
If use multiple drivers, how to get them to be 8ohm impedance?
Also what is the best solution for the sub-woofer for both rooms? (Close and open space?)
^_^
Old 30th November 2012, 02:22 AM   #14
frugal-phile(tm)
planet10's Avatar
I don't know why you are so stuck on 8 ohm impedance?
dave
Old 30th November 2012, 04:40 AM   #15
dave
I already have 2 AVR that are 8 ohm impedance, and I want to match them.
Is it ok for HT system to use 8ohm and 16ohm together in the same setting?
Old 30th November 2012, 04:47 AM   #16
frugal-phile(tm)
planet10's Avatar
Yes it is OK. And with a typical AVR higher impedance surrounds are probably a good thing. Leaves more current for the mains.
dave
Old 30th November 2012, 04:51 AM   #17
dave
I will definetly try them out, then. (on the Splayed Surround.)
Thank you for the clarify that for me.
^_^
Old 13th December 2012, 07:11 PM   #18
somehow I ended up with the Pensil-10.2 for my first pair of Markaudio's drivers, and they sound very nice.
I'll use them as my front speakers. Then I'll build one sealed box using Alpair-10 as center speaker, and a pair of Pensil R70.3 for the surround speakers.
to be continue...
^_^
Old 13th December 2012, 10:59 PM   #19
to be continue...
^_^
looking good - sounds like you'll have a very decent "little" HT rig when the sawdust settles
now on sabbatical
Old 14th December 2012, 04:18 AM   #20
skeeter99's Avatar
Those are stunning!! Very nice build!
Scott
DIY virtual surround / 5.1 speakers front placement pelanj Multi-Way 8 4th December 2008 09:57 PM
HT Surround Speakers Viking552 Multi-Way 20 21st February 2007 01:21 AM
very near field HT surround speakers metaldwarf Multi-Way 21 20th January 2006 04:37 AM
3 Way HT Front Speakers Using Tang Band W3-871S pietschu Multi-Way 0 9th May 2004 09:00 PM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 10:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
