#41 |
I've been working on my Gen.1 Alpair 10 (notch filters) using Dave's surplus Fonken boxes over the Christmas break - so I thought I'd chime in to express my wishlist for a future EL166 woofer (I have a pair of them as well). I've read the thread discussion regarding the difficulties of mass production, inventories and competing products. My take on the matter is produce a value oriented product but use several unique features to differentiate it from competing products. My dream woofer from Mark would include: natural paper cone, natural rubber surround, and a natural coloured Alpair frame -"all natural"
and just for grins, an incorporated embossed EnABLed pattern on the cone near the surround edge (instead of the embossed cone rings on the prevoius design). Given the past performance of Mark's drivers, I wouldn't hesitate to pay 2X the price of the EL166 and, perhaps, this would compensate for smaller production runs. Certainly, the monochromatic colour of the woofer would help it stand out in a crowded marketplace. Thanks again to Mark for participating in this forum and supporting to the DIY market. Cheers, Ron Listening to: Echo and the Bunnymen - Ocean Rain |
#42 |
My inspiration - fitting with Markaudio's Asian heritage and manufacture
#43 |
There are other players in this arena. Pansies are not allowed on the court.
#44 | |
A set of interesting comments, keep them coming. Ref. your statement (see the highlighted red text), please exercise more care as its a large over-simplification. While I appreciate you posting your opinions, your not a driver designer so its best to ask questions regarding the function and performance of cones. Cones have a complex job to perform. For Full-Range/Wide band drivers, they have to oscillate (mechanical movement) and resonate (vibrate) in one operation and be part of the linear damping power-train arrangement. A cone by itself can't be considered "pistonic and linear", its the whole power-train that is required to perform these functions. The major components controlling linearity are the suspensions, the design of these items is more complex than the cone in many cases. A good performing Full-Range cone will have to be both resonant and micro-resonant capable. Driver designers with enough knowledge will chose a flex ratio, area to material mass ratio and design a dispersion profile to deliver the desired performance goal. For woofers in domestic home audio, the issue of generating micro-resonance remains. Should the designer wish to produce a unit capable of re-producing reasonably accurate music in the lower frequency ranges, he/she must address the issue of keeping mass low and design accordingly. Sadly, most driver designers are "forced" into over-massing, over stiffening cones simply to handle marketing hyped power demands. Please feel free to comment further but lets get away from over-simplified assertive comment. Your ideas are interesting, think more about how better to present them. Thanks Mark. Last edited by markaudio; 11th January 2013 at 10:53 PM. |
#45 | |
Last edited by markaudio; 14th January 2013 at 10:36 PM. Reason: removing commercial conflict |
#46 | |
This section of your last post is good. Less confrontational and appreciative of other members views. Lets see more of this style in your future posts. The first part of your previous post was confusing. You appeared to advocate the use of stiff heavy cones, something that runs against Markaudio design knowledge/philosophy/application. Should you wish to expand/advocate your assertive views about heavy stiff coned woofs/subs, the Sub-woofer section of Diyaudio is the appropriate place: Subwoofers - diyAudio For those members who wish to follow Tux's system design ideas, he's made a new thread on the full range section: Cross Over design and Woofer choices for FAST Mark Last edited by markaudio; 14th January 2013 at 11:48 PM. |
#47 |
Mark, be proud of Woofer No.6 (EL-166) no matter what speakerbox I have put it in, it has always sounded amazing and suppriesed me in the best possibly way. Everything from small 9 liter "soft wall" box to THAM6 witch is a small tapped horn, more info here Martinsson's Blog - .
Next build is a "clone" of a swedish speaker OM2000 that Olle Mirsch built in 1985... ![]() Dimensioner: 70 x 32 x 25 cm, 1 Woofer No.6 and 2 Tweeter No.3, simple seriel crossover. I just regret not to buying more, i'm a lucky owner of two pairs, one white and one black. Guess it is time to place a order on some more Tweeter No.3 i think, as you only regret what you didn't do, and I do regret that I didn't got more Woofer No.6. Best regards |
#48 |
Guys,
Many thanks for the various views and ideas raised on this thread, all much appreciated. There's allot for me to ponder. Feel free to keep your ideas coming. Its possibly time for me to focus on the outline design of the next Woof: It will be a lower power handling unit. My cone/power-train design knowledge affords me the opportunity to make an LF emitter that micro-resonant capable. Its cone will be able to carry and emit complex waves forms necessary for the more accurate detailed reproduction of music. Commercially, its a risky approach but having pondered all the views on this thread, I can't betray Markaudio's low-mass design philosophy. As to size, range, SPL, look, paper or metal etc etc, I'm open to continuing ideas, thoughts based upon the principle I've outlined. For those members who strongly support and advocate high power-handling LF drivers with higher massed power-trains, use the other forums (like the Sub-woofer section) to expound your thinking on this aspect of driver design and function. Thanks Mark. Last edited by markaudio; 14th January 2013 at 11:28 PM. |
#49 |
Well I'm fine with low mass low power high fidelity devices, since I hope to go in that direction as a human approaching 70 years myself. I still have the 1958 vintage Ampex console that my father provided as our basis for learning about music via recordings and radio. 12 watt 6V6 pp amps and 8" FR speaks in asymmetrical enclosures are the basis of my ear, so moving to wide range plus woofer is totally natural. I'm still disappointed in the failure of multiway systems to convince me, but so be it. We still don't have multiway microphones as far as I know.
#50 | |
Thanks for your comments and support. You've hit the nail squarely on the head with by linking "low power" with "high fidelity". Sadly today, in the context of most musical re-production, many end-users have been negatively influenced by the sectors of the industry that more power delivers more quality. For those members and observers of Diyaudio, a recap of the basic definition of original-histoical "High Fidelity" is: That the reproduction is as close to the original source as possible Granted there are degrees of "grey" in this debate. Those guys into "rock un roll, heavy beat/house music and dramatic home theatre, might naturally lean towards heavier duty speaker drivers and big amps. They might argue that in the case of some of their sourced material, it demands a system of large proportions. For example, the Terminator films might be at their most dramatic when played on large power audio systems. I don't have any problem with their system design approach in this context. However, in the context of accurate musical re-production, their high-power philosophy won't work well. There is a misguided assumption amongst some members who fall into the "power" camp, that somehow a big thick cone can "magically" create accurate musical output, for example a basso profundo (baritone) vocal, or the subtle nuance of the Double Bass. Those of us who have professional driver design knowledge knows the physics and mechanics involved and understand the design limitations of such an approach. Like member phivates (et.al) I've rarely been convinced by 2 way or multiway systems. I have only found a few gems in all my years. Those members who know me well might recall my passion for the Victor SX500 Spirit series (I've got 2 pairs in mint/near mint condition): VICTOR ƒXƒs[ƒJ[ƒVƒXƒeƒ€SX-500‚ÌŽd—l ƒrƒNƒ^[ Norio Nakajima san has recently produced a corker (fab) of a small 2 way named the "Duo 60" - see pic. He spent around 200 hours of experimental time just to get the cross-overs sorted. I'm more than happy to support such a high level of dedication - see pic. Markaudio concentrates its efforts on the design and manufacture of drivers that focus on historical/traditional High Fidelity concepts and thinking. Technically, our expertise is in low mass wide band drivers so it makes natural sense for us to mostly stay in the sector we understand best. Thanks Mark. Last edited by markaudio; 15th January 2013 at 02:58 AM. |
| Thread Tools | Search this Thread |
| Woofer-Fullrange-Woofer vs Tweeter-Midrange-Woofer | fakeout | Multi-Way | 5 | 11th August 2012 06:17 PM |
| VAM1202 out of production ? | ashok | Chip Amps | 5 | 12th January 2010 08:01 PM |
| Tubes currently in production | Nevod | Tubes / Valves | 4 | 3rd August 2008 10:47 AM |
| Best production EL34? | Pyre | Tubes / Valves | 39 | 26th December 2007 12:32 AM |
| Is piezosource in production yet? | Mikael Abdellah | Planars & Exotics | 0 | 7th January 2007 06:58 PM |
