Go Back   Home > Forums > Commercial Sector > Manufacturers > Markaudio
Markaudio Designers and builders of audiophile grade drivers
Old 5th November 2012, 10:04 PM   #11
markaudio's Avatar
Hi Guys,
This work is at a very early stage. We're some way off a workable per-production prototype. I will do my best to post more information over the coming weeks/months, hoping to gauge the level of support for future driver development.
Mark.
Old 5th November 2012, 10:06 PM   #12
markaudio's Avatar
Originally Posted by chrisb View Post
Mark - how do you explain the rather significant difference in the impedance spikes between the neo and Alnicos posted in the other thread, and have any of these been listened to yet?
Hi Chris,
I think you're referring to the CHR-Alnic test unit. Its got a weak strength motor, hence the very limited impedance output.
The Alpair 6P Neo had a quick listen (already commented in that thread)
Mark.
Old 5th November 2012, 10:09 PM   #13
markaudio's Avatar
Originally Posted by 18Hurts View Post
It should not be too costly,
They are full ranges, not woofers or subwoofers so considerably less expensive since so much neo is not needed or desired.
In theory, I've heard neo "can" improve high frequencies so worth looking into. Might do the trick with the A10 and 12P since the larger drivers would embrace any additional treble response.
No stone left unturned with Mark--should be educational to see how this plays out.
Hi 18,
Neo is mostly used on small drivers where space saving is critical. Due to its cost, its rarely used on larger units.
Mark
AR Super 8 Neodymium OR Tang Band W8-1772 8" Neodymium ken mead Full Range 0 5th October 2012 02:39 PM
neodymium speakers ? rmsaudio Multi-Way 32 6th July 2012 08:41 AM
Got neodymium? Andrew Eckhardt Everything Else 18 12th September 2010 03:39 PM
If neodymium is all that great . . . Bill Fitzpatrick Multi-Way 153 8th October 2008 09:05 AM
AlNiCo vs. Neodymium Timn8ter Full Range 10 2nd November 2004 08:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
